Good evening all!
I am working with a SIM808 whihc manage the incoming call, SMS, etc.
The is a list of unsolicited code result on my Serial1 port which is mixed with my AT response
For exmple:
RING
NO CARRIER
UNDER VOLTAGE
NORMAL POWERDOWN
+CMTI:
If you know SIM808 from simcom, is there a way to manage the unsolicited code, as for exemple, forward it the the Hardware Serial?
Or can I disable all unsolicited code, or a specific one
Actuallay the RING give me some trouble, because each time I call my module RING is merged with my AT+ repsose. It will have the same issue with +CMTI when a SMS is received.
The best way, it to disable it, and enbale with when my code is waiting or checking for an incoming call!
(I do not need the check +CMTI, because I am using an AT+ command to check the saved unread SMS.
Thank for your help!!!
