How to manipulate C strings
I'm in the process of learning C strings at the moment, but there's something that I have not been able to work out yet.
Suppose I have a C string (character array) that looks like this:
char currentTime = "+CIPSNTPTIME:Sun Jun 07 15:30:00 2020"
NOTE: In the example above, I'm manually setting that array, but in my program, this is actually what is returned by a WiFi adapter after an SNTP time query.
My issue is that I want to drop off the "+CIPSNTPTIME:" part of the array so that the array simply contains this: "Sun Jun 07 15:30:00 2020".
How can I accomplish this?
Take a look at this
There is an entire library of reliable routines to manipulate C-strings.
Start here: http://www.cplusplus.com/reference/cstring/
An obvious approach is to use strtok() to split the string at the first ':'.
Have a look at the existing C library functions in stdlib.h and string.h
Why do you want to? If you have a function that's going to do something with the 'new' string, you can just leave the original alone and just pass & currentTime[13].
Doh! Wildbill - that's a great simple solution. Admittedly, though, that was only one sample situation. I still need to understand how to manipulate strings, so thank you all for the pointers (pun intended).
I'm still getting used to the entire C++ strings implementation.
Thanks again.
