#include <ESP8266WiFi.h>
#include <ESP8266mDNS.h>
#include <ArduinoOTA.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>
#include <DNSServer.h>
const char* ssid = "";
const char* password = "";
ESP8266WebServer server(80);
String ipAddress = "";
const char* www_username = "admin2020";
const char* www_password = "esp8266";
ArduinoOTA.begin();
server.on("/", [](){
if(!server.authenticate(www_username, www_password))
return server.requestAuthentication();
server.send(200, "text/plain", "Login OK");
server.begin();
Serial.print("Open http://");
Serial.println("/ in your browser to see it working");
//WiFiManager
//Local intialization. Once its business is done, there is no need to keep it around
WiFiManager wifiManager;
//reset saved settings
wifiManager.resetSettings();
//set custom ip for portal
//wifiManager.setAPStaticIPConfig(IPAddress(192,168,1,44), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
//fetches ssid and pass from eeprom and tries to connect
//if it does not connect it starts an access point with the specified name
//here "AutoConnectAP"
//and goes into a blocking loop awaiting configuration
wifiManager.autoConnect("SmarttechPublicToiletRoll");
//or use this for auto generated name ESP + ChipID
//wifiManager.autoConnect();
//if you get here you have connected to the WiFi
Serial.println(":HTTP server connected!)");
ArduinoOTA.handle();
server.handleClient();
HI, i am using ESP8266 board.I want to create a OTA server to lock the wifi manager connection. Before people want to went in wifi manager service they need to login OTA server example: they need go browser to type in the IP adress to entre the user_name and password to be able to unlock the wifi-manager service. But after i restart the wifi-manager it ip adress become 192.168.4.1 the static ip adress for ESP8266 and i unable to connect to 192.168.4.1 using my browser. Is there any way to solve it ? Or any way to let the people to connect the wifi inside the OTA server ? Like when they entered the ip address and type in the username and password to able let them connect the wifi inside the website ? Sorry for my bad english.
i tried this code . wanted to open a Ethernet server for customer login type in ssid and password but it shown my ip adress 255.255.255.255 . WiFI manager my ip adress is WM: 192.168.8.225
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] ={
00-A0-D1-A7-F4-26 };
IPAddress ip(10,1,1,1);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
void SendOKpage(EthernetClient &client)
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connnection: close");
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// add a meta refresh tag, so the browser pulls again every 5 seconds:
client.println("<meta http-equiv=\"refresh\" content=\"5\">");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("
client.println("</html>");
void SendAuthentificationpage(EthernetClient &client)
client.println("HTTP/1.1 401 Authorization Required");
client.println("WWW-Authenticate: Basic realm=\"Secure Area\"");
client.println();
client.println("<HTML> <HEAD> <TITLE>Error</TITLE>");
client.println(" </HEAD> <BODY><H1>401 Unauthorized.</H1></BODY> </HTML>");
char linebuf[80];
int charcount=0;
boolean authentificated=false;
// listen for incoming clients
if (client) {
Serial.println("new client");
memset(linebuf,0,sizeof(linebuf));
charcount=0;
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
linebuf[charcount]=c;
if (charcount<sizeof(linebuf)-1) charcount++;
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
if (authentificated)
SendOKpage(client);
SendAuthentificationpage(client);
if (c == '\n') {
// you're starting a new line
if (strstr(linebuf,"Authorization: Basic")>0 && strstr(linebuf,"c2F0YXJ1bjpwYXNzd29yZA==")>0)
authentificated=true;
charcount=0;
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disonnected");
