Hello, I have a question about the Arduino's current usage. I want to play around with some sleep modes to save power from a Li-ion, single cell battery. Before I go sticking multimeter leads in places that I should not, where is the best place to measure current in the Arduino when connected USB? I haven't connected the battery yet, and currently my friend has it on him. A simple 'red lead to +5V and the other to pin so and so' would be good enough for me. Thanks in advance for checking this.
bullroarer:
You can't really do it when it's connected to USB. The current measuring device has to go in series with the power supply.
https://learn.sparkfun.com/tutorials/how-to-use-a-multimeter/measuring-current
Connected a 9V battery and got ~48mA. Found that to be normal after a little research. Now I want to put it into sleep mode and measure the current. will I connect my multimeter leads the same way?
Measuring current draw from a USB port on a PC can be a little problmatic from a practical side. That's why I jumped on the below cute little item a few months ago when I came across it. Seems to work ok but not the most rugged thing I've come across. Alternates display from volts to milliamps and I haven't verified it's accuracy yet, but at the price I couldn't resist.
http://www.ebay.com/itm/390646012397?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The range is nice for how little it is. I can already see where my problem is going to be. I've calculated all my power while connected to the USB port. I'm using a solar panel with a 3.7 li-ion battery. There's going to small differences that will have some effect on the output power, but I doubt it will that big of a deal.
Kudos to the find! Looks to be something a USB stick would like to have by its side.
I think the regular arduino board uses a linear regulator, which wastes the extra voltage so maybe sleeping with a switching regulator is a better choice?
bullroarer:
Yes.
liudr:
That looks like it would do the trick, I'll keep that in mind when I print a new board for the Arduino.
