How to measure RPM from vehicle tires? Wheel Speed Sensor
I'm looking for a Wheel Speed Sensor to use it with a Raspberry Pi/Arduino project to measure RPMs from a vehicle tires, however, I can only found sensor devices that I can't use with vehicle tires, they are for smaller purposes.
There are several ways to do it:
-Hall Effect
-Reed Switch
-IR Sensor
I've found some sensors from companies but they are builded for specific devices from them.
I hope to receive some help from you guys! Thanks
Assuming that the tyre is reasonably securely attached to the wheel, you might find it simpler to measure the wheel speed more directly. Any Hall-effect bike speedo has an rpm facility and can be adjusted over a wide range of tire circumference. $2-50.
