I assume 50mA is the maximum allowed current for the LED? Do you have a link to the LED's datasheet? The Arduino I/O pins can't provide that much current. It will light-up at less current, but it won't be quite as bright.
I've read that if I connect some pin to GND I'll shortcut the arduino. So is it possible for me to test the current with my tester connecting the 5v pin to a resistor and then back to GND?
The phrase is "short circuit" or "short out".
No! You can measure the voltage (with a multimeter) but the Arduino is can provide enough current to (potentially) burn itself out! If you try to measure the maximum current with a multimeter you can fry your Arduino! You CAN measure current in an existing circuit (the current through an LED, etc.), but in order to measure current you have to "break" the circuit and insert the meter in series. In practice, we measure voltage & resistance a lot but we rarely measure current.
Each I/O pin is rated at 40mA "absolute maximum". The "standard" Arduino boards run from 5V and the I/O pins put-out (approximately) 5V when high, and (approximately) zero volts (or "ground potential) when low.
I don't know how much amps does my resistor have that is the reason why I want to do that.
Current depends on voltage and resistance as defined by [u]Ohm's Law[/u] (Current in Amps = Voltage / Resistance in Ohms).
If you take an electronics class, Ohm's Law is the first thing you learn.
LEDs are a bit tricky... LEDs (like all diodes) are non-linear. The resistance changes when you change voltage.
When the voltage is low, resistance is high and almost no current flows.
As you approach the diode's breakdown voltage (operating voltage for an LED) the resistance suddenly goes to almost zero and lots of current flows (if it's not somehow limited).
This means we can't use Ohms Law on the LED because we don't know it's resistance.
But, the good news is we CAN use Ohm's Law on the resistor that's in series with the LED.
You need to know two more things, which are related to [u]Kirchhoff's Laws[/u].
1. The same current flows through all series components. (If we can calculate the current through the resistor, we know the same current is flowing through the LED.)
2. The voltage is divided among the series components. (You can actually figure that out from Ohm's Law once you know the same current is flowing through all series components.)
OK... Now we get to the answer...
We can't get 50mA without damaging the Arduino, so let's say 40mA.
With 5V divided between the LED and resistor, and with 3.5V across the LED, we'll have 1.5V across the resistor.
We re-arrange Ohm's Law as 1.5V / .040 Amps = 37.5 Ohms. That's the minimum resistance. With lower resistance, you'll get too much current. So, choose a standard resistor value greater than 37.5 Ohms.
