how to measuring angle with gyroscope ?
Hi everybody,
After a few weeks of bad tries, I need help today.
(sorry for bad english, I'm french)
So, my company makes wiper motor/arm/blade for windshield of planes and helicopter. http://www.falgayras.com/
My job is to make benchtest at the end of line production.
Our motor is wiping the widows with a discontinuous movement. Not a full turn but move to reach a max angle return to low position (min angle) and do it again and again and again....same as a car :slight_smile:
I have to measure the max and min angle over a period of 1mn (one minute)
I started using accelerometer, but the results was an acceleration (of course) not an angular position. As I have to measure cycle over the minute, i cannot give a speed reference since I have to measure it as well.
I used a mouse (optical) from a computer to measure the distance (pi ratio) on a mechanical part at the motor axis, but zero reference is moving and never the same value when motor axis is in the SAME angular position.
I can't use an optical sensor such as wheel with little hole on the circumference because our motor setup is vibrating to much.
Now I have a rotativ sensor such as potentiometer but more reliable and long lasting life for using in production department.
It's a magnetic sensor.
The problem is : "transfering the rotative movement in good condition and repetitive setup for workers"...I sure need a drive belt...(wich I want to avoid)
So I try with gyroscope (in fact I wish it was my first idea). ref=> tinkerkit T00000062 (RS : 758-9351)
I have seen many exampes code, but I'm still lost since I'm a begginer in arduino and not specialist in writing code
Still reading ? thank you :slight_smile:
My problem is that the value from sensor (after treatment ) is still moving up or down.
I can memorize max end min angle, (thx to clever functions) but how to code in order to stabilize position ?
I used the code given in the datasheet, but seems more dedicated to quadricopter, anyway, I kept somes lines and checked them on my motor. Still the same, when motor is not turning, the angle value is running by itself from 0 to 360°...
I read that : [u]Arduino Playground - HomePage but not so helpfull for me.
I have a nokia LCD wich I get back from my old 3310 :slight_smile:
here's my last code (display is for debugging), not the final version
#include <PCD8544.h>
static const byte sensorPin = 5;
static PCD8544 lcd;
float gyrorate = 0;
float gyroadc = 0;
float gyrozero = 0;
float gyroangle = 0;
int t1 = 0;
int t2 = 0;
int dt = 0;
lcd.begin(84, 48);
gyrozero = analogRead(sensorPin); // memorize value in zero/parking position of motor
t1 = millis();
lcd.setCursor(0, 0);
lcd.print("gyrozero=");
lcd.print(gyrozero);
lcd.print(" ");
lcd.setCursor(0, 2);
lcd.print("gyroadc= ");
gyroadc = analogRead(sensorPin);
t2 = millis();
lcd.print(gyroadc);
gyrorate = (gyroadc-gyrozero) / 0.2077; // sensitivity : (0,00067/3,3)*1023 = 0,2077 3,3 is voltage
dt = t2 - t1; // delta time between parking position and reading time of sensor
lcd.setCursor(0,1);
lcd.print("dt=");
lcd.print(dt);
lcd.setCursor(0, 3);
lcd.print("gyrorate=");
lcd.print(gyrorate);
lcd.print(" ");
gyroangle += (gyrorate * dt)/1000; // use delta time to calculate angle reached at each time
lcd.setCursor(0, 4);
lcd.print("gyroangle=");
lcd.print(gyroangle); // display angle
lcd.print(" ");
In fact I would like an inclinometer
Anyone can give some advices please ?
Thanks a lot for reading till here, I hope you understood what I wrotte , i forgot my english.
According web and/or google I may have to use derivative functions, what do you think ?
BR
Arnaud
Arnaud_M:
It's normal for a gyro to output constant movement even when at rest. This is referred to as "drift". A drift around 10 degrees/second is typical.
If you can add some point of reference for the position of the wiper blade then you can eliminate the drift error everytime the blade passes that point. In other words, if you used a limit switch, hall sensor/magnet, or optical sensor that would tell you everytime the blade is at the midpoint between the min/max sweep then you would know that you need to turn a set amount of degrees more from that point. The drift would not be a big issue then.
Regarding inclinometers, those still employ accelerometers. They're not going to help you here.
Gyro sensor measures rate of rotation, not angle.
To measure the rotation angle of your screen wiper, I'd suggest using one of those contactless magnetic rotary position encoders. I can't remember the name right now, they have been mentioned quite often in this forum, try searching for rotary encoder and you will probably come across it, they are made in Austria.
