how to merge 3 sketches in to one sketch
i did try to merge 3 sketches into one, each of them works well,
but not together, what do i do wrong?
a lot of faults, try to make an web weather station,
first a web server sketch, then an digital sensor, and at last an windmeter,
*includeall nesesary librarys
setup(){
setupwebserver();
setupdigitalsensor();
setupwindmeter();
loop(){
voidwebserver();
voiddigitalsensor};
voidwindmeter();
concept weerstation.txt (6.13 KB)
temperatuur meter.txt (3.22 KB)
webserver.txt (1.51 KB)
windmeter.txt (2.08 KB)
Without seeing the code that is in your functions it is impossible to help.
Have you made sure that one part is not trying to use the same resource (eg an I/O pin) as another part.
...R
See here:-
http://www.thebox.myzen.co.uk/Tutorial/Merging_Code.html
loop(){
voidwebserver();
voiddigitalsensor};
voidwindmeter();
void is not part of the name of a function, you don't use it when you call a function.
You seemed to have “concept weerstation.txt” pretty close to being the merge of the other three. What part is not working? Are you getting a compile error? If so, what. I tried to do the merge myself but I don’t have the libraries you have and don’t want to take the time to track them down.
#include <Wire.h>
#include <ArduinoWiFi.h>
//#include <WiFi.h>
// DHT Temperature & Humidity Sensor
// Unified Sensor Library Example
// Written by Tony DiCola for Adafruit Industries
// Released under an MIT license.
// Depends on the following Arduino libraries:
// - Adafruit Unified Sensor Library: https://github.com/adafruit/Adafruit_Sensor
// - DHT Sensor Library: https://github.com/adafruit/DHT-sensor-library
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
#define DHTPIN            2         // Pin which is connected to the DHT sensor.
// Uncomment the type of sensor in use:
//#define DHTTYPE           DHT11     // DHT 11
#define DHTTYPE           DHT22     // DHT 22 (AM2302)
//#define DHTTYPE           DHT21     // DHT 21 (AM2301)
// See guide for details on sensor wiring and usage:
//   https://learn.adafruit.com/dht/overview
//DHT_Unified dht(DHTPIN, DHTTYPE);
dht dht(DHTPIN, DHTTYPE);
uint32_t delayMS;
int serial_in;
//Setup Variables windmeter
double x = 0;
double y = 0;
const int sensorPin = A1; //Defines the pin that the anemometer output is connected to
int sensorValue = 0; //Variable stores the value direct from the analog pin
float sensorVoltage = 0; //Variable that stores the voltage (in Volts) from the anemometer being sent to the analog pin
float windSpeed = 0; // Wind speed in meters per second (m/s)
float voltageConversionConstant = .004882814; //This constant maps the value provided from the analog read function, which ranges from 0 to 1023, to actual voltage, which ranges from 0V to 5V
int sensorDelay = 2000; //Delay between sensor readings, measured in milliseconds (ms)
//Anemometer Technical Variables
//The following variables correspond to the anemometer sold by Adafruit, but could be modified to fit other anemometers.
float voltageMin = .4; // Mininum output voltage from anemometer in mV.
float windSpeedMin = 0; // Wind speed in meters/sec corresponding to minimum voltage
float voltageMax = 2.0; // Maximum output voltage from anemometer in mV.
float windSpeedMax = 32; // Wind speed in meters/sec corresponding to maximum voltage
  Wifi.begin();
  Wifi.println("WebServer Server is up");
  // Initialize device.
  dht.begin();
  Serial.println("DHTxx Unified Sensor Example");
  // Print temperature sensor details.
  sensor_t sensor;
  dht.temperature().getSensor(&sensor);
  Serial.println("------------------------------------");
  Serial.println("Temperature");
  Serial.print  ("Sensor:       "); Serial.println(sensor.name);
  Serial.print  ("Driver Ver:   "); Serial.println(sensor.version);
  Serial.print  ("Unique ID:    "); Serial.println(sensor.sensor_id);
  Serial.print  ("Max Value:    "); Serial.print(sensor.max_value); Serial.println(" *C");
  Serial.print  ("Min Value:    "); Serial.print(sensor.min_value); Serial.println(" *C");
  Serial.print  ("Resolution:   "); Serial.print(sensor.resolution); Serial.println(" *C");
  // Print humidity sensor details.
  dht.humidity().getSensor(&sensor);
  Serial.println("Humidity");
  Serial.print  ("Max Value:    "); Serial.print(sensor.max_value); Serial.println("%");
  Serial.print  ("Min Value:    "); Serial.print(sensor.min_value); Serial.println("%");
  Serial.print  ("Resolution:   "); Serial.print(sensor.resolution); Serial.println("%");
  Serial.println("Ted van den Hoogen,s eigen weerstation Geertruidenberg ");
  // Set delay between sensor readings based on sensor details.
  delayMS = sensor.min_delay / 1000;
  while (Wifi.available()) {
    process(Wifi);
  delay(50);
  // Delay between measurements.
  delay(delayMS);
  // Get temperature event and print its value.
  sensors_event_t event;
  dht.temperature().getEvent(&event);
  if (isnan(event.temperature)) {
    Serial.println("Error reading temperature!");
  else {
    Serial.print("Temperature: ");
    Serial.print(event.temperature);
  // Get humidity event and print its value.
  dht.humidity().getEvent(&event);
  if (isnan(event.relative_humidity)) {
    Serial.println("Error reading humidity!");
  else {
    Serial.print("Humidity: ");
    Serial.print(event.relative_humidity);
  sensorValue = analogRead(sensorPin); //Get a value between 0 and 1023 from the analog pin connected to the anemometer
  sensorVoltage = sensorValue * voltageConversionConstant; //Convert sensor value to actual voltage
  //Convert voltage value to wind speed using range of max and min voltages and wind speed for the anemometer
  if (sensorVoltage <= voltageMin) {
    windSpeed = 0; //Check if voltage is below minimum value. If so, set wind speed to zero.
    windSpeed = ((sensorVoltage - voltageMin) * windSpeedMax / (voltageMax - voltageMin) * 2.23694);
  //Max wind speed calculation
  x = windSpeed; if (x >= y) {
    y = x;
    y = y;
  //Print voltage and windspeed to serial
  Serial.print("\t");
  Serial.print("Wind speed: ");
  Serial.println(windSpeed);
void process(WifiData client) {
  // read the command
  String command = client.readStringUntil('/');
  if (command == "webserver") {
    WebServer(client);
void WebServer(WifiData client) {
  client.println("Content-Type: text/html");
  client.println("Connection: close");
  client.println("Refresh: 20");  // refresh the page automatically every  sec
  client.println();
  client.println("<html>");
  client.println("<head> <title>UNO WIFI Example</title> </head>");
  client.print("<body>");
  for (int analogChannel = 0; analogChannel < 4; analogChannel++) {
    int sensorReading = analogRead(analogChannel);
    client.print("analog input ");
    client.print(analogChannel);
    client.print(" is ");
    client.print(sensorReading);
    client.print("
  client.print("</body>");
  client.println("</html>");
  client.print(DELIMITER); // very important to end the communication !!!
