How to merge strings?
How can I merge two strings?
Let’s say I have strings:
char* myString = “test”;
char* mySecondString = “done”;
char* testString = “testdone”;
and now I need to merge myString and mySecondString to get a string equal to testString.
I’ve tried:
  • myString,mySecondString
    and
  • strcat(myString,mySecondString)
but I do not get a string equal to testString…
any idea?
You need to declare a buffer big enough to hold the merged string.
char buffer[9]; // larger enough to hold the combined string and the terminating null
strcpy(buffer, myString);
strcat(buffer, mySecondString);
mem what do I make wrong?
char* myString = "test";
char* mySecondString = "done";
char* testString = "testdone";
char buffer[9];
  if(buffer == testString){
    Serial.println("true");
  }else{
    Serial.println("false");
I get “false”.
Is not a valid comparison for C strings.
“strcmp (testString, buffer) == 0”
Explanation:
“buffer” is the address of the memory location “buffer [0]”, and “testString” is the address of “testString [0]” ; the two values are unlikely to ever be equal.
it works, thanks a lot!
