I am trying to configure and Anarduino miniWirteless with a dual-optiboot from Moteino.
FYI Anarduino and Moteino are running on a AtmelMega38P-AU, 16 MHz powered by 3v3.
The miniWireless is running a Duemilanove bootloader.
Anarduino Miniwireless and Moteino are equivalent (beside the SPI Flash Ram, but this is another topic)
So I am trying to reprogram the miniWireless with the Dua-optiboot (see DualOptiboot/DualOptiboot_V5.0_atmega328_BlinkD9.hex at master · LowPowerLab/DualOptiboot · GitHub)
I did follow the MUSHClient instruction to get a ‘.h’ file (note that I had to add a new Send/Start value of 7C00).
This file named “bootloader_atmega328P_dual_boot.h” is added as part of the Atmega_Board_Programmer directory
From the Board.txt I know that the Fuse is (see below extract of the board.txt):
Moteino.bootloader.low_fuses=0xDE
Moteino.bootloader.high_fuses=0xDC
Moteino.bootloader.extended_fuses=0xFD -
Now what about the signature? I suppose it is 0x1E 0x95 0x0F
QUESTIONS: -
How can I associate this new file in the Atmega_Board_Programmer.ino sketch?
Thanks in advance
Robert
Attachement:
// File = DualOptiboot_V5.0_atmega328_BlinkD9.hex
// Loader start: 7C00, length: 1024
// MD5 sum = D2 AF FE B5 5E D1 B4 FE A6 47 FE 45 2F 86 50 B1
const byte DualOptiboot_V5_0_atmega328_BlinkD9_hex [] PROGMEM = {
0x11, 0x24, 0x04, 0xB7, 0x14, 0xBE, 0x01, 0xFD, 0x04, 0xC0, 0x03, 0xFD, 0x24, 0xD1, 0x80, 0x2F,
0xDF, 0xD1, 0x85, 0xE0, 0x80, 0x93, 0x81, 0x00, 0x82, 0xE0, 0x80, 0x93, 0xC0, 0x00, 0x88, 0xE1,
0x80, 0x93, 0xC1, 0x00, 0x86, 0xE0, 0x80, 0x93, 0xC2, 0x00, 0x80, 0xE1, 0x80, 0x93, 0xC4, 0x00,
0x8E, 0xE0, 0xFB, 0xD0, 0x21, 0x9A, 0x86, 0xE0, 0x20, 0xE3, 0x3C, 0xEF, 0x91, 0xE0, 0x30, 0x93,
0x85, 0x00, 0x20, 0x93, 0x84, 0x00, 0x96, 0xBB, 0xB0, 0x9B, 0xFE, 0xCF, 0x19, 0x9A, 0xA8, 0x95,
0x81, 0x50, 0xA9, 0xF7, 0xEE, 0x24, 0xFF, 0x24, 0xAA, 0x24, 0xA3, 0x94, 0xB5, 0xE0, 0xCB, 0x2E,
0xA1, 0xE1, 0xBA, 0x2E, 0xF3, 0xE0, 0xDF, 0x2E, 0xD2, 0xD0, 0x81, 0x34, 0x61, 0xF4, 0xCF, 0xD0,
0x08, 0x2F, 0xE1, 0xD0, 0x02, 0x38, 0x29, 0xF1, 0x01, 0x38, 0x11, 0xF4, 0x85, 0xE0, 0x01, 0xC0,
0x83, 0xE0, 0xBD, 0xD0, 0x7F, 0xC0, 0x82, 0x34, 0x11, 0xF4, 0x84, 0xE1, 0x03, 0xC0, 0x85, 0x34,
0x19, 0xF4, 0x85, 0xE0, 0xD8, 0xD0, 0x76, 0xC0, 0x85, 0x35, 0x79, 0xF4, 0xB8, 0xD0, 0xE8, 0x2E,
0xFF, 0x24, 0xB5, 0xD0, 0x08, 0x2F, 0x10, 0xE0, 0x10, 0x2F, 0x00, 0x27, 0x0E, 0x29, 0x1F, 0x29,
0x00, 0x0F, 0x11, 0x1F, 0xC0, 0xD0, 0x78, 0x01, 0x65, 0xC0, 0x86, 0x35, 0x21, 0xF4, 0x84, 0xE0,
0xC2, 0xD0, 0x80, 0xE0, 0xDE, 0xCF, 0x84, 0x36, 0x09, 0xF0, 0x40, 0xC0, 0xA0, 0xD0, 0x9F, 0xD0,
0x08, 0x2F, 0x9D, 0xD0, 0x80, 0xE0, 0xE8, 0x16, 0x80, 0xE7, 0xF8, 0x06, 0x18, 0xF4, 0xF7, 0x01,
0xD7, 0xBE, 0xE8, 0x95, 0xC0, 0xE0, 0xD1, 0xE0, 0x92, 0xD0, 0x89, 0x93, 0x0C, 0x17, 0xE1, 0xF7,
0xF0, 0xE0, 0xEF, 0x16, 0xF0, 0xE7, 0xFF, 0x06, 0x18, 0xF0, 0xF7, 0x01, 0xD7, 0xBE, 0xE8, 0x95,
0x9A, 0xD0, 0x07, 0xB6, 0x00, 0xFC, 0xFD, 0xCF, 0xA7, 0x01, 0xA0, 0xE0, 0xB1, 0xE0, 0x2C, 0x91,
0x30, 0xE0, 0x11, 0x96, 0x8C, 0x91, 0x11, 0x97, 0x90, 0xE0, 0x98, 0x2F, 0x88, 0x27, 0x82, 0x2B,
0x93, 0x2B, 0x12, 0x96, 0xFA, 0x01, 0x0C, 0x01, 0xA7, 0xBE, 0xE8, 0x95, 0x11, 0x24, 0x4E, 0x5F,
0x5F, 0x4F, 0xF1, 0xE0, 0xA0, 0x38, 0xBF, 0x07, 0x51, 0xF7, 0xF7, 0x01, 0xC7, 0xBE, 0xE8, 0x95,
0x07, 0xB6, 0x00, 0xFC, 0xFD, 0xCF, 0xB7, 0xBE, 0xE8, 0x95, 0x1C, 0xC0, 0x84, 0x37, 0x61, 0xF4,
0x5E, 0xD0, 0x5D, 0xD0, 0x08, 0x2F, 0x5B, 0xD0, 0x6E, 0xD0, 0xF7, 0x01, 0x85, 0x91, 0x7F, 0x01,
0x4E, 0xD0, 0x01, 0x50, 0xD1, 0xF7, 0x0E, 0xC0, 0x85, 0x37, 0x39, 0xF4, 0x64, 0xD0, 0x8E, 0xE1,
0x46, 0xD0, 0x85, 0xE9, 0x44, 0xD0, 0x8F, 0xE0, 0x84, 0xCF, 0x81, 0x35, 0x11, 0xF4, 0x88, 0xE0,
0x54, 0xD0, 0x59, 0xD0, 0x80, 0xE1, 0x3B, 0xD0, 0x6F, 0xCF, 0x8E, 0xBD, 0x0D, 0xB4, 0x07, 0xFE,
0xFD, 0xCF, 0x8E, 0xB5, 0x08, 0x95, 0x28, 0x98, 0x85, 0xE0, 0xF7, 0xDF, 0x80, 0xE0, 0xF5, 0xDF,
0x28, 0x9A, 0x81, 0x70, 0x08, 0x95, 0x1F, 0x93, 0x18, 0x2F, 0x66, 0x23, 0x21, 0xF0, 0x86, 0xE0,
0x60, 0xE0, 0xF9, 0xDF, 0x28, 0x9A, 0xEF, 0xDF, 0x88, 0x23, 0xE9, 0xF7, 0x28, 0x98, 0x81, 0x2F,
0xE4, 0xDF, 0x1F, 0x91, 0x08, 0x95, 0xEF, 0x92, 0xFF, 0x92, 0x0F, 0x93, 0x1F, 0x93, 0x7B, 0x01,
0x8C, 0x01, 0x83, 0xE0, 0x60, 0xE0, 0xE7, 0xDF, 0xC8, 0x01, 0xAA, 0x27, 0xBB, 0x27, 0xD5, 0xDF,
0xBB, 0x27, 0xA1, 0x2F, 0x90, 0x2F, 0x8F, 0x2D, 0xD0, 0xDF, 0x8E, 0x2D, 0xCE, 0xDF, 0x80, 0xE0,
0xCC, 0xDF, 0x28, 0x9A, 0x1F, 0x91, 0x0F, 0x91, 0xFF, 0x90, 0xEF, 0x90, 0x08, 0x95, 0x98, 0x2F,
0x80, 0x91, 0xC0, 0x00, 0x85, 0xFF, 0xFC, 0xCF, 0x90, 0x93, 0xC6, 0x00, 0x08, 0x95, 0x19, 0x9A,
0x80, 0x91, 0xC0, 0x00, 0x87, 0xFF, 0xFC, 0xCF, 0x80, 0x91, 0xC0, 0x00, 0x84, 0xFD, 0x01, 0xC0,
0xA8, 0x95, 0x80, 0x91, 0xC6, 0x00, 0x19, 0x9A, 0x08, 0x95, 0xE0, 0xE6, 0xF0, 0xE0, 0x98, 0xE1,
0x90, 0x83, 0x80, 0x83, 0x08, 0x95, 0xEB, 0xDF, 0x80, 0x32, 0x19, 0xF0, 0x88, 0xE0, 0xF5, 0xDF,
0xFF, 0xCF, 0x84, 0xE1, 0xDC, 0xCF, 0x1F, 0x93, 0x18, 0x2F, 0xE1, 0xDF, 0x11, 0x50, 0xE9, 0xF7,
0xF2, 0xDF, 0x1F, 0x91, 0x08, 0x95, 0x9F, 0x92, 0xAF, 0x92, 0xBF, 0x92, 0xCF, 0x92, 0xDF, 0x92,
0xEF, 0x92, 0xFF, 0x92, 0x0F, 0x93, 0x1F, 0x93, 0xCF, 0x93, 0xDF, 0x93, 0x80, 0xE0, 0xDD, 0xDF,
0x84, 0xB1, 0x8D, 0x62, 0x84, 0xB9, 0x28, 0x9A, 0x1A, 0x9A, 0x8C, 0xB5, 0x80, 0x65, 0x8C, 0xBD,
0x28, 0x98, 0x8F, 0xE9, 0x82, 0xDF, 0x80, 0xE0, 0x80, 0xDF, 0x28, 0x9A, 0x81, 0x50, 0x8E, 0x3F,
0x08, 0xF0, 0x92, 0xC0, 0x81, 0xE0, 0x61, 0xE0, 0x86, 0xDF, 0x80, 0xE0, 0x76, 0xDF, 0x28, 0x9A,
0x60, 0xE0, 0x70, 0xE0, 0x80, 0xE0, 0x90, 0xE0, 0x8E, 0xDF, 0x86, 0x34, 0x09, 0xF0, 0x84, 0xC0,
0x61, 0xE0, 0x70, 0xE0, 0x80, 0xE0, 0x90, 0xE0, 0x86, 0xDF, 0x8C, 0x34, 0x09, 0xF0, 0x7C, 0xC0,
0x62, 0xE0, 0x70, 0xE0, 0x80, 0xE0, 0x90, 0xE0, 0x7E, 0xDF, 0x88, 0x35, 0x09, 0xF0, 0x74, 0xC0,
0x66, 0xE0, 0x70, 0xE0, 0x80, 0xE0, 0x90, 0xE0, 0x76, 0xDF, 0x8A, 0x33, 0x09, 0xF0, 0x6C, 0xC0,
0x69, 0xE0, 0x70, 0xE0, 0x80, 0xE0, 0x90, 0xE0, 0x6E, 0xDF, 0x8A, 0x33, 0x09, 0xF0, 0x64, 0xC0,
0x67, 0xE0, 0x70, 0xE0, 0x80, 0xE0, 0x90, 0xE0, 0x66, 0xDF, 0x08, 0x2F, 0x68, 0xE0, 0x70, 0xE0,
0x80, 0xE0, 0x90, 0xE0, 0x60, 0xDF, 0x10, 0xE0, 0xF0, 0x2E, 0xEE, 0x24, 0x90, 0xE0, 0xE8, 0x2A,
0xF9, 0x2A, 0xE0, 0xFC, 0x51, 0xC0, 0x19, 0x9A, 0xC0, 0xE0, 0xD0, 0xE0, 0xCC, 0x24, 0xDD, 0x24,
0x99, 0x24, 0x93, 0x94, 0x43, 0xE0, 0xA4, 0x2E, 0x35, 0xE0, 0xB3, 0x2E, 0x30, 0xC0, 0x2A, 0x96,
0xBE, 0x01, 0x80, 0xE0, 0x90, 0xE0, 0x47, 0xDF, 0x08, 0x2F, 0x10, 0xE0, 0x21, 0x96, 0xBE, 0x01,
0x80, 0xE0, 0x90, 0xE0, 0x2B, 0x97, 0x3F, 0xDF, 0x90, 0xE0, 0x98, 0x2F, 0x88, 0x27, 0x80, 0x2B,
0x91, 0x2B, 0xFE, 0x01, 0x0C, 0x01, 0x97, 0xBE, 0xE8, 0x95, 0x11, 0x24, 0x22, 0x96, 0xCE, 0x01,
0x8F, 0x77, 0x90, 0x70, 0x89, 0x2B, 0x19, 0xF0, 0xCE, 0x15, 0xDF, 0x05, 0x81, 0xF4, 0xF6, 0x01,
0xA7, 0xBE, 0xE8, 0x95, 0x07, 0xB6, 0x00, 0xFC, 0xFD, 0xCF, 0xF6, 0x01, 0xB7, 0xBE, 0xE8, 0x95,
0x07, 0xB6, 0x00, 0xFC, 0xFD, 0xCF, 0x80, 0xE8, 0x90, 0xE0, 0xC8, 0x0E, 0xD9, 0x1E, 0xCE, 0x15,
0xDF, 0x05, 0x08, 0xF4, 0xCC, 0xCF, 0x19, 0x98, 0x81, 0xE1, 0x87, 0xBF, 0xE8, 0x95, 0x82, 0xE5,
0x61, 0xE0, 0x01, 0xDF, 0x80, 0xE0, 0xF1, 0xDE, 0x80, 0xE0, 0xEF, 0xDE, 0x80, 0xE0, 0xED, 0xDE,
0x28, 0x9A, 0x88, 0xE0, 0x3A, 0xDF, 0xFF, 0xCF, 0xDF, 0x91, 0xCF, 0x91, 0x1F, 0x91, 0x0F, 0x91,
0xFF, 0x90, 0xEF, 0x90, 0xDF, 0x90, 0xCF, 0x90, 0xBF, 0x90, 0xAF, 0x90, 0x9F, 0x90, 0x08, 0x95,
0x28, 0x2E, 0x80, 0xE0, 0x2A, 0xDF, 0xEE, 0x27, 0xFF, 0x27, 0x09, 0x94, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x05,
}; // end of DualOptiboot_V5_0_atmega328_BlinkD9_hex
Moteino board.txt
Moteino.name=Moteino
Moteino.upload.tool=avrdude
Moteino.upload.protocol=arduino
Moteino.upload.maximum_size=31744
Moteino.upload.speed=115200
Moteino.bootloader.path=Moteino
Moteino.bootloader.file=DualOptiboot_V5.0_atmega328_BlinkD9.hex
Moteino.bootloader.unlock_bits=0x3F
Moteino.bootloader.lock_bits=0xCF
Moteino.build.mcu=atmega328p
Moteino.build.f_cpu=16000000L
Moteino.build.core=arduino:arduino
Moteino.build.variant=arduino:standard
Moteino.build.board=AVR_MOTEINO
