Hi every one
I am new to Arduino and could make a project with an UNO board to turn a dc motor left and right but according the programming style, the 0 should be dialed to turn off the motor any time the motor is turned right or left by dialing 1 and 2 but I would like to know how to modify the program or using a new recommended program that can enable me set a fixed time for running dc motor without needing to dial 0 to stop turning.
I hereby send the complete code for you study and assistance.
Appreciated your advise in advance
Regards
Control DC motor with Smartphone via bluetooth
2013
int motorPin1 = 3; // pin 2 on L293D IC
int motorPin2 = 4; // pin 7 on L293D IC
int enablePin = 5; // pin 1 on L293D IC
int state;
int flag=0; //makes sure that the serial only prints once the state
// sets the pins as outputs:
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(enablePin, OUTPUT);
// sets enablePin high so that motor can turn on:
digitalWrite(enablePin, HIGH);
// initialize serial communication at 9600 bits per second:
//if some date is sent, reads it and saves in state
if(Serial.available() > 0){
state = Serial.read();
flag=0;
// if the state is '0' the DC motor will turn off
if (state == '0') {
digitalWrite(motorPin1, LOW); // set pin 2 on L293D low
digitalWrite(motorPin2, LOW); // set pin 7 on L293D low
if(flag == 0){
Serial.println("Motor: off");
flag=1;
// if the state is '1' the motor will turn right
else if (state == '1') {
digitalWrite(motorPin2, HIGH); // set pin 7 on L293D high
if(flag == 0){
Serial.println("Motor: right");
flag=1;
// if the state is '2' the motor will turn left
else if (state == '2') {
digitalWrite(motorPin1, HIGH); // set pin 2 on L293D high
if(flag == 0){
Serial.println("Motor: left");
flag=1;
