how to move file from SD card to the pc using internet
HI
I'm using the Arduino to log data on to an SD card and I would like to be able to transfer that file on the card to my Windows PC for further use it, through WIFI.
how can i make that possible.
Thanks,
soufiane
By far the simplest thing is to move the SD Card to the PC.
After that (if you want wireless) it would probably be easier and cheaper with Bluetooth which just creates a wireless serial link.
If you really need WiFi you could perhaps use an ESP8266 WiFi module or a WiFi shield. An Arduino Yun (which comes with WiFi and an SD Card slot) would probably be easiest as you could do all the web programming in Python.
Assuming you have a WiFi capability on your Arduino you will need to set it up as a small web server which can read the data from the SD Card and send it in response to a request. NOTE that you can only have one program on an Arduino so this server stuff would have to be built as an extra part of your data collection program.
Then on your PC you will need a program that can send a request to the server to get the data.
...R
I’m using the Arduino to log data on to an SD card and I would like to be able to transfer that file on the card to my Windows PC for further use it, through WIFI.
Test code that may do what you want. This code serves HYPNO.JPG from the SD card to a browser for display via a wireless connection between my notepad and the router.
//zoomkat 12/26/12
//SD server test code
//open serial monitor to see what the arduino receives
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = {
  192, 168, 1, 102 }; // ip in lan
byte gateway[] = {
  192, 168, 1, 1 }; // internet access via router
byte subnet[] = {
  255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
  // disable w5100 while setting up SD
  pinMode(10,OUTPUT);
  digitalWrite(10,HIGH);
  Serial.print("Starting SD..");
  if(!SD.begin(4)) Serial.println("failed");
  else Serial.println("ok");
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  //delay(2000);
  server.begin();
  Serial.println("Ready");
void loop(){
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
            client.println("HTTP/1.1 200 OK"); //send new page
          //client.println("Content-Type: text/html");
          client.println("Content-Type: image/jpeg");
          //client.println("Content-Type: image/gif");
          //client.println("Content-Type: application/x-javascript");
          //client.println("Content-Type: text");
          client.println();
          //File myFile = SD.open("boom.htm");
          File myFile = SD.open("HYPNO.JPG");
          //File myFile = SD.open("BLUEH_SL.GIF");
          //File myFile = SD.open("SERVOSLD.HTM");
          if (myFile) {
            byte clientBuf[64];
            int clientCount = 0;
            while(myFile.available())
              clientBuf[clientCount] = myFile.read();
              clientCount++;
              if(clientCount > 63)
                // Serial.println("Packet");
                client.write(clientBuf,64);
                clientCount = 0;
            //final <64 byte cleanup packet
            if(clientCount > 0) client.write(clientBuf,clientCount);
            // close the file:
            myFile.close();
          delay(1);
          //stopping client
          client.stop();
          readString="";
