how to move random servo
I have a bank of 4 servos, I am getting a random number from 2-5 and want to move a servo based on that number. It is all working fine if I use a switch case in the logic, but I would like to remove the switch case and make the write call dynamic.
#include <Servo.h>
Servo myS2;
Servo myS3;
Servo myS4;
Servo myS5;
int randomInt = 0;
int prevRand = 0;
  randomSeed( analogRead(A0) );
  myS2.attach(2);
  myS3.attach(3);
  myS4.attach(4);
  myS5.attach(5);
  for(int x=0; x < 10; x++){
    randomInt = random(2,6);
    while(randomInt == prevRand){
    prevRand = randomInt;
    switch (randomInt) {
    case 2:
      myS2.write(5);
    case 3:
      myS3.write(5);
    case 4:
      myS4.write(5);
    case 5:
      myS5.write(5);
I have tried adding in these variables
char choice = 'mys';
char choice2;
then replacing the switch with this
choice2 = choice + randomInt;
choice2.write(5);
so i was essentially trying to dynamically write that class name and add it in to the write, but I am getting this error
request for member ‘write’ in ‘choice2’, which is of non-class type ‘char’
any ideas on another way to make that part dynamic?
Use a random index into an array of function pointers (servo.write functions).
You cannot create source code at runtime, C++ is not a dynamic language in that sense.
You need an array of servo objects.
While it is possible to use an array of pointers and that would be a good solution for more than a handful, the switch case is pretty good. That would be my choice for this application.
Why do you think the switch is bad? Your code looks really good to me.
