How to move the servo without interrupt DHT11 for Visual Basic
hi, so i’m working on a new project for my class. im really new to arduino programming, and this program is for visual basic 2010 Express.
I want this program to be able to read DHT11 continuously, and at the same time I can move the servo (in visual basic I use trackbar).
but the program that I made sadly works like this:
when the servo given a command to moves (for example to an angle: 180) it will moves to angle 180, but then a few seconds later it will return to its original position (angle: 0) without any command.
so the question is, how to correct this program so that the servo does not return to the initial position before it is given a command to angle 0, while at the same time the program is reading the sensor?
I have no idea how to write/correct it, please help me… thanks a lot!
p.s. I use google translate, but i hope it still understandable for you
this is the program:
#include "DHT.h"
#define DHTPIN 12
#define DHTTYPE DHT11   // DHT 11
#include <Servo.h>
Servo myservo;
DHT dht(DHTPIN, DHTTYPE);
int data[3] = {0,0,0};
int pos = 0;
String TextForSms ;
String humidity = " Humidity: %";
String temperature = "   Temperature";
String sign = " *C";
char fromc; // character from computer
  dht.begin(); //dht11 : pin 12
  myservo.attach(9);  // servo : pin 9
  myservo.write(2);
  delay(200); //DHT 11 program
  int h = dht.readHumidity();
  int t = dht.readTemperature();
  int f = dht.readTemperature(true);
  if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
  int hi = dht.computeHeatIndex(f, h);
  TextForSms = TextForSms + t + "," + h + ",";
  Serial.println(TextForSms);
     TextForSms = "";
Serial.available()==0; { //servo program
pos=Serial.parseInt();
myservo.write(pos);
 delay(25);
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
Serial.available()==0; { What’s that for?
Please remember to use code tags when posting code
Other threads removed.
thankyou so much! i wont do such thing again
hello, this problem is finally solved after so much trial-error and i tried any kind of possibility, because i'm really new in arduino.
so, in case anyone has the same problem like me, here is the last line code that already changed:
int pos;
if (Serial.available()) {
delay(100);
while(Serial.available()>0) {
myservo.write(pos);
pos=" "; } }
thankyou so much!
    int pos=Serial.parseInt();
    myservo.write(pos);
pos=" "; Have a good long think about that.
c_hyemiiiii:
You forgot your [​code][​/code] code tags again, didn't you?
The while is unnecessary once you've already checked Serial.available(). I removed it.
No idea what purpose the delay serves. I left it in just in case.
Variable "pos" is an int. What the heck is assigning a string to it with pos = " " supposed to do?
    delay(100);
    myservo.write(pos);
