How to move to parent directory with SdFat library
Hello,
I am currently trying to build a system which needs to read file in SD card.
I found that there might be two ways to change directory to parent.
First one is using SdFat::chdir, as follows. void loop() and other functions are not included.
#include <SdFat.h>
SdFat sd;
const uint8_t SD_CS_PIN = 53;
if (!sd.begin(SD_CS_PIN)) sd.initErrorHalt();
sd.chdir("subdirectory");
I tried using chdir as follows.
sd.chdir("..");
But, this effort did not work.
The other way is using SdBaseFile::openParent as follows. I have modified SdBaseFile.h to change openParent to Public in order to to this.
SdBaseFile file;
file.openParent(sd.vwd());
But, this effort did not also work.
Do you have idea how to move to parent directory?
