How to multi-task
Hi :slight_smile: ,
How do I run multiple tasks in Arduino? I tried with a multiplexer 1838HXL (74hc595) via this link but without success! Then I tried with the millis() function by following this [link] (https://www.carnetdumaker.net/articles/faire-plusieurs-choses-la-fois-avec-une-carte-arduino/) but I doubt the reliability of the data since I connect to analog, I could very well not connect my sensor and still have a result in console. Can you tell me what you think?
int LED1 = 12;
int LED2 = 11;
int buzzer = 10;
int sensorThreshold = 400;
void setup(){
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  pinMode(buzzer, OUTPUT);
  pinMode(A0, INPUT);
void loop(){
  task_MQ2();
  task_MQ3();
  task_MQ4();
  task_MQ5();
void task_MQ2(){
  int analogSensor = analogRead(A0);
  Serial.print("Pin A0/MQ2: ");
  Serial.println(analogSensor);
  if (analogSensor > sensorThreshold)
    digitalWrite(LED1, HIGH);
    digitalWrite(LED2, LOW);
    tone(buzzer, 1000, 200);
    digitalWrite(LED1, LOW);
    digitalWrite(LED2, HIGH);
    noTone(buzzer);
void task_MQ3() {
  int analogSensor = analogRead(A1);
  Serial.print("Pin A1/MQ3: ");
void task_MQ4() {
  int analogSensor = analogRead(A2);
  Serial.print("Pin A2/MQ4: ");
void task_MQ5() {
  int analogSensor = analogRead(A3);
  Serial.print("Pin A3/MQ5: ");
Pin A0/MQ2: 322
Pin A1/MQ3: 314
Pin A2/MQ4: 480
Pin A3/MQ4: 544
Pin A0/MQ2: 322
Pin A1/MQ3: 313
Pin A2/MQ4: 480
Pin A3/MQ4: 544
Pin A0/MQ2: 322
Pin A1/MQ3: 313
Pin A2/MQ4: 480
Pin A3/MQ4: 544
Pin A0/MQ2: 322
Pin A1/MQ3: 313
Pin A2/MQ4: 480
Pin A3/MQ4: 543
Pin A0/MQ2: 323
What do you perceive the problem to be?
circuit in series rather than in parallel
I'm sorry, in your original post, you said "without success".
What did that refer to?
That's the proper approach. However, delays shouldn't be used. Used millis() to schedule the running inside the functions.
void task_MQ3() {
  static unsigned long timeStamp = 0;
  if (millis() - timeStamp >= 500) {
  timeStamp += 500;
Ok I will use millis()
I have no other problem so I put this topic as solved
ps. @ TheMemberFormerlyKnownAsAWOL in my first idea, I failed to use un MUX (multiplexer 1838HXL | 74hc595) I didn't understand how it works
Thanks
True. a 74HC595 is not a multiplexer.
