How to name the temperature sensors instead of printing address using ds2482-100 and ds18b20 sensor- Help
Hello all, I am using 10 ds18b20 Temperature sensors using with "DS2482-100" I2C board
so when I am getting the output like this:- "ROM = 28 46 04 1F 0D 00 00 74 96014B467FFF0A100A 25.3 2699 Dc", so Instead of address I want to name it "Sensor-1" any tutorial or help would be appreciated.
 Arduino library for controlling DS2482-100 and DS2482-800 1-wire masters.
 Uses Wire library to communicate with DS2482 so be sure to call Wire.begin() before using the library.
 Quick example modeled after Onewire example:
#include <OneWire.h>
#include <Wire.h>
#include <DS2482.h>
#include <DallasTemperature.h>
DS2482 ds(0);  //channels ds2482-800 is 0 to 7, DS2482-100 is just set 0
byte data[9]; //holding for onewire capture
byte addr[9]; //1wire wire address and CRC
long time_temp;
uint8_t sensor1[8] = { 0x28, 0x00, 0xF9, 0x1E, 0x0D, 0x00, 0x00, 0x76 };
uint8_t sensor3[8] = { 0x28, 0x61, 0x64, 0x12, 0x3F, 0xFD, 0x80, 0xC6 };
 Wire.begin();
 ds.reset();
 pinMode(13, OUTPUT);
 // start serial port
 Serial.begin(57600);
 time_temp = millis();
 //do search
 if ( !ds.wireSearch(addr))
   if(addr == sensor1)
   Serial.print("sensor1");
   Serial.print("No more addresses.\n");
   ds.wireResetSearch();
   return;
 Serial.print("ROM =");
 for ( int i = 0; i < 8; i++) {
   Serial.write(' ');
   if (addr[i] < 16) Serial.print("0");
   Serial.print(addr[i], HEX);
 if (ds.crc8(addr, 7) != addr[7]) {
   Serial.println("CRC is not valid!");
   return;
 //test if device code DS18b20
 if (addr[0] == 0x28) {
   //read temperature data.
   ds.wireReset();
   ds.selectChannel(0);
   ds.wireSelect(addr);
   ds.configure(0x05); //set bus on strong pull-up after next write until next command
   ds.wireWriteByte(0x44); //convert temperature on this device
   delay(770); //wait for conversion 750ms Plus margin
   ds.wireReset();
   ds.wireWriteByte(0xbe);         // Read Scratchpad command
   //display hex values of scratchpad
   Serial.print(" ");
   for ( int i = 0; i < 9; i++) {           // we need 9 bytes to capture CRC
     data[i] = ds.wireReadByte();
     if (data[i] < 16)Serial.print("0");
     Serial.print(data[i], HEX);
   Serial.print(" ");
   //convert to decimal temperature
   int LowByte = data[0];
   int HighByte = data[1];
   int TReading = (HighByte << 8) + LowByte;
   int SignBit = TReading & 0x8000;  // test most sig bit
   if (SignBit) // negative
     TReading = (TReading ^ 0xffff) + 1; // 2's comp
   int Tc_100 = (double)TReading * 0.0625 * 10;
   if (SignBit) // If its negative
     Tc_100 = 0 - Tc_100;
   //print temp for each device
   Serial.print(Tc_100 / 10);
   Serial.print(".");
   Serial.print(Tc_100 % 10);
   Serial.print(" ");
   Serial.print(millis() - time_temp);
   Serial.println(" Dc");
Another users who does not read the advice on posting code properly or chooses to ignore it
The easier you make it to read and copy the code the more likely it is that you will get help
Please follow the advice given in the link below when posting code , use code tags and post the code here
Complete sentences help also.
I think you are asking about the name to use when creating an instance of library code. You can name them anything you like. George and Gracie, for example.
