I'm using the sensor to return distance to me and here's the code I'm using:
const int trigPin = 9;
const int echoPin = 10;
const uint8_t vibrate_pin = 6;
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
long duration, distance;
digitalWrite(trigPin, LOW);
delay(5);
//delayMicroseconds(20);
digitalWrite(trigPin, HIGH);
delay(10);
//delayMicroseconds(100);
duration = pulseIn(echoPin, HIGH);
distance= (duration*0.034)/2;
if(distance <= 75 && distance >= 51){
analogWrite(vibrate_pin, 100);
}else if(distance <= 50 && distance >= 26){
analogWrite(vibrate_pin, 200);
}else if(distance <= 25 && distance >= 1){
analogWrite(vibrate_pin, 960);
}else{
analogWrite(vibrate_pin, 0);
//Serial.print("Distance: ");
Serial.println(distance);
This works fine for what I'm trying to do, however, every once in a while I have a +3000 cm value. This is a screenshot of it:
I'm wondering how can I change my code to ignore any value that's above some specific value X. I would like it to be totally ignored, not even printed in the monitor even. I'm a programming noob so sorry if this is obvious.
do you mean something like this ?
long duration, distance, distance_corrected;
delay(5);
delay(10);
}else{
if (distance < 3000 ) { //change the value to whatever you want
distance_corrected = distance;
lenny227:
delay(5);
delay(10);
}else{
Yes, this is what I needed. Thank you!
Alternative (and it makes your code faster):
duration = pulseIn(echoPin, HIGH, 6000);
6000 µs is about 2 meters of travel at 330 m/s, so a distance of 1 meter. Your code checks for up to 75 cm so that's enough.
If the timeout is reached, the function returns 0. Minimum for the sensor is about 2 cm, anything less is probably a false reading.
Or the NewPing library's median method: Arduino Playground - NewPing Library NewPing has been around for a long time.
Not sure why one library is better than another for this simple device, or why a library is needed at all, really.
The "NewPing" is very cool library, but complicated & heavy. My does pretty much the same, but has a smaller foot print.
