How to notify email without press reset button
Serial.print("distance ( ): ");
Serial.println(distance);
Serial.print("Level (Ml): ");
Serial.println(levelMl);
display.clearDisplay();
display.setCursor(0, 25);
//Display level in Liter
display.print(distance);
display.print("");
// Display distance in inches
/* display.print(distanceInch);
display.print(" in");*/
display.display();
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
/** Enable the debug via Serial port
  • none debug or 0
  • basic debug or 1
    smtp.debug(1);
/* Set the callback function to get the sending results */
smtp.callback(smtpCallback);
/* Declare the session config data */
ESP_Mail_Session session;
/* Set the session config */
session.server.host_name = SMTP_HOST;
session.server.port = SMTP_PORT;
session.login.email = AUTHOR_EMAIL;
session.login.password = AUTHOR_PASSWORD;
session.login.user_domain = "";
/* Declare the message class */
SMTP_Message message;
/* Set the message headers */
message.sender.name = "GARBAGE MONITORING SYSTEM POLITEKNIK MERSING";
message.sender.email = AUTHOR_EMAIL;
message.subject = "STATUS GARBAGE";
message.addRecipient("Afrina", RECIPIENT_EMAIL);
//Send HTML message/
String htmlMsg = "<div style="color:#2f4468;">
GARBAGE IS FULL!
- Please pickup the rubbish
message.html.content = htmlMsg.c_str();
message.text.charSet = "us-ascii";
message.html.transfer_encoding = Content_Transfer_Encoding::enc_7bit;
/* Set the custom message header */
//message.addHeader("Message-ID: abcde.fghij@gmail.com");
/* Connect to server with the session config */
if (!smtp.connect(&session))
return;
/* Start sending Email and close the session */
if (!MailClient.sendMail(&smtp, &message))
Serial.println("Error sending Email, " + smtp.errorReason());
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
digitalWrite(trigPin, LOW);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculate the level
distance = duration * SOUND_SPEED/2;
// Convert to inches
//levelMl = distance * LITER_TO_ML;
Serial.println (distance);
if (distance >= 2 && distance <= 9) {
Serial.println ("STATUS = FULL \n ") ;
Serial.println ("100%");
digitalWrite (led1, HIGH);
digitalWrite (led2, LOW);
digitalWrite (led3, LOW);
digitalWrite(oledPin,HIGH);
display.print ("STATUS = FULL \n ") ;
display.print ("100%");
delay(900);
else if (distance >= 10 && distance <= 20 ) {
Serial.println ("STATUS = HALF \n ") ;
Serial.println ("50%");
digitalWrite(oledPin,LOW);
digitalWrite (led1, LOW);
digitalWrite (led2, HIGH);
display.print ("STATUS = HALF \n ") ;
display.print ("50%");
delay(900);
else {
Serial.println ("STATUS = LOW \n ") ;
digitalWrite (led3, HIGH);
display.print("STATUS = LOW \n ");
delay(900);
display.display();
/* Callback function to get the Email sending status /
void smtpCallback(SMTP_Status status){
Print the current status */
Serial.println(status.info());
/* Print the sending result */
Serial.println("----------------");
delay(900);
ESP_MAIL_PRINTF("Message sent success: %d\n", status.completedCount());
ESP_MAIL_PRINTF("Message sent failled: %d\n", status.failedCount());
struct tm dt;
delay(900);
struct tm dt;
else {
delay(900);ESP_MAIL_PRINTF("Message sent failled: %d\n", status.failedCount());
struct tm dt;
for (size_t i = 0; i < smtp.sendingResult.size(); i++){
  /* Get the result item */
  SMTP_Result result = smtp.sendingResult.getItem(i);
  time_t ts = (time_t)result.timestamp;
  localtime_r(&ts, &dt);
  ESP_MAIL_PRINTF("Message No: %d\n", i + 1);
  ESP_MAIL_PRINTF("Status: %s\n", result.completed ? "success" : "failed");
  ESP_MAIL_PRINTF("Date/Time: %d/%d/%d %d:%d:%d\n", dt.tm_year + 1900, dt.tm_mon + 1, dt.tm_mday, dt.tm_hour, dt.tm_min, dt.tm_sec);
  ESP_MAIL_PRINTF("Recipient: %s\n", result.recipients.c_str());
  ESP_MAIL_PRINTF("Subject: %s\n", result.subject.c_str());
Serial.println("----------------\n");
Welcome to the forum
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Please post your full sketch, using code tags when you do
