How to number Loops with IR Remote
Hi I am very new to Arduino. How do I number my for loops with an IR Remote?
Ex. I Press 3 on IR Remote and the code loops 3 times.
The code consists of two dc motors, servo motor, and a LED light so I think a switch case will be a lot of copy and paste and compiling. Or can I condense the code somehow and turn it into a function that I can repeat?
The code:
#include <IRremote.h>
#include <Servo.h>
////// DATA //////
enum phase {
powertest,wait ,stage1, stage2, stage3, STOP
#define power 0xFF30CF
#define led 4
#define BM 9
#define I1 8
#define I2 5
#define FM 11
#define I3 13
#define I4 12
int RECV_PIN=3;
int track;
int posi=0;
int pos=150;
IRrecv irrecv(RECV_PIN);
decode_results results;
Servo j;
irrecv.enableIRIn();
pinMode(led,OUTPUT);
pinMode(8,OUTPUT);
pinMode(5,OUTPUT);
pinMode(9,OUTPUT);
pinMode(11,OUTPUT);
pinMode(12,OUTPUT);
pinMode(13,OUTPUT);
j.attach(10);
j.write(posi);
switch(track){
case powertest:
//// light test ///
digitalWrite(led,HIGH);
digitalWrite(led,LOW);
//// motor test////
//// motor BM test ////
digitalWrite(I1,LOW);
digitalWrite(I2,HIGH);
analogWrite(BM,255);
delay(1500);
digitalWrite(I1,HIGH);
digitalWrite(I2,LOW);
delay(1500);
analogWrite(BM,0);
/// motor bm test end////
///motor fm test////
delay(2000);
digitalWrite(I3,HIGH);
digitalWrite(I4,LOW);
analogWrite(FM,255);
delay(1500);
digitalWrite(I3,LOW);
digitalWrite(I4,HIGH);
delay(1500);
analogWrite(FM,0);
/// motor fm test end///
//// servo test////
j.write(pos);
delay(1500);
j.write(posi);
track = wait;
case wait:
if(irrecv.decode(&results)){
  unsigned int value = results.value;
  switch(value){
    case power:
  irrecv.resume();
delay(1500);
track = stage1;
case stage1:
not sure what you want to do, do something 3 times when a specific IR code is received?
the code has 3 states. in the initial state it toggles LEDs with delays between, then changes to state wait.
in wait it monitors the IR and sets an LED if it receives the "power" value, then turns it off after 1.5 sec.
there may have been a desire to change state, but it's preceded by a break, so it is never set
        track = stage1;
in general, seems that you would want loop() the code inside your "wait" case to be the primary code inside loop()
void loop () {
    if (irrecv.decode (&results)){
        switch (value) {
        case power:
        case other-key-codes:
        irrecv.resume ();
if things needs to be done separately from when an IR code is received, a simple switch statement based state machine can also be included in loop() where state may be set when a specific IR codes are received
    switch (state){
    case action1:
        state = ??;
    case action2:
        state = ??;
    case action3:
        state = ??;
and if some timed processing is required, loop() can also include the following where timeout is set when an IR code is received or in a state
    static unsigned long msecLst;
           unsigned long msec     = millis ();
    if (timout && (msec - msecLst) > timeout)  {
        timeout = 0;     // OR msecLst = msec
