How to off analogRead from reading value ? URGENT
I would like to know when button 's' if pressed, then the analogRead will stop reading value from sensor.
Read this for how to read a button
Then use an if statement to see if you need to perform an analogue read function.
Grumpy_Mike:
http://arduino.cc/en/Tutorial/DigitalReadSerial
For my case, i mean when char 's' is detected not the digitalpin from arduino
int incomingByte = 0;   // for incoming serial data
        Serial.begin(9600);     // opens serial port, sets data rate to 9600 bps
        // send data only when you receive data:
        if (Serial.available() > 0) {
                // read the incoming byte:
                incomingByte = Serial.read();
               if(incomingByte != 's') {
                // put here the code to read the analogue input and do what you want with it
Posting some code to show what you've done so far would help.
I assume you mean an 's' from the computer keyboard via usb from say the serial monitor?- if so have you got Serial.read() working to monitor what's coming in? Then use that result to control what you do using something like a while or an if
EDIT.... just like G_M said 8)
JimboZA:
Ya... you get what i mean. I know when coming data 's'/ 'S', then i wan know the code on how to stop the sensor from sensing any values? or switch off the sensor.
You are not clear in what you are asking.
You do not write code to stop a sensor sensing, you write code to read the value from a sensor.
What sort of sensor do you have, it is not normal to turn off a sensor your code should simply not read it.
You need to specify what you want to do with the readings from your sensor.
Is this homework?
Grumpy_Mike:
Is this homework?
I am using Hall effect sensor.
#define NOFIELD 505L // Analog output with no applied field, calibrate this
// This is used to convert the analog voltage reading to milliGauss
#define TOMILLIGAUSS 1953L // For A1301: 2.5mV = 1Gauss, and 1024 analog steps = 5V, so 1 step = 1953mG
void DoMeasurement()
char btn;
btn=(char)Serial.read();
int flag=0;
if(btn==‘a’){//activate sensor
flag =1;
while(flag==1)
// measure magnetic field
int raw = analogRead(A0); // Range : 0…1024
long compensated = raw - NOFIELD; // adjust relative to no applied field
long gauss = compensated * TOMILLIGAUSS / 1000; // adjust scale to Gauss
if (gauss <0)
Serial.print(gauss*-1);
else{
Serial.print(gauss);
if(btn==‘s’){
//here i dont know what to write
delay(5);
DoMeasurement();
I think you may need to re-structure a bit, perhaps put G_M's suggestion in the loop
                DoMeasurement();
JimboZA:
DoMeasurement();
Cannot work, the system will hang.
Why does a function called DoMeasurement do anything at all to the serial port?
you need a small state machine , OK a gift because it is Christmas
// see also - http://playground.arduino.cc/Code/HallEffect
// Uncomment one of the lines below according to device in use A1301 or A1302
// #define TOMILLIGAUSS 3756L  // For A1302: 1.3mV = 1Gauss, and 1024 analog steps = 5V, so 1 step = 3756mG
int state = 0;   // 0 == off,    1 == start
    if (incomingByte == 's') state = 1;     // s = start
    if (incomingByte == 'q') state = 0;   // q = quit
  if (state == 1) DoMeasurement();
  int raw = analogRead(A0);   // Range : 0..1023
  if (gauss < 0) Serial.println(gauss * -1);
  else Serial.println(gauss);
Ok Rob, I have to ask.... how did you get the "not tested" into the code tag?
you can edit the code tags, but its a secret, don't tell anyone :wink:
[ code=secret]
off course without the space ..
We live and learn...
check - http://docs.simplemachines.org/index.php?topic=735.0 -
Is your HTML study going well?
robtillaart:
check - Alphabetical list of all bulletin board codes - Online Manual -
Yes thanks, busy with forms and cgi as we speak......
