How to open a text file
Hello I have saved the serial data from the arduino to a text file using COOL TERM software.. but I would like to open the same data("which is in a .TXT file ") and print on serial..
**This text file is in my local machine not on SD
Looking for some suggestions..!
THanks
Sai
You should be able to open a .txt file with any text editor.
I don't understand what you mean by "print on serial"
If you mean that you want to view the text file in the Arduino Serial Monitor then I can't think of any easy way to do so. But neither can I think of any reason to do so. The Arduino Serial Monitor is intended to show data coming from the Arduino.
...R
Thanks Robin...!
Your terminal program should be able to open a file and send it out on the serial port to the Arduino. I use RealTerm, but I expect CoolTerm is similar.
