How to open PCB file from github
Hi, I downloaded all the PCB file from https://github.com/sb-ocr/ocreeb-12/tree/main/PCB, but how to open the gbr file? I have import the "Ocreeb 12.sch" by Autodesk Eagle but can't open.
You need a gerber viewer. I don't think Eagle gives you one
http://gerbv.geda-project.org/
For the gerber you need a gerber viewer ( you can fine online too )
Take a look at KiCad, it does conversions. Best if you can get the original file and load it with your design program.
@willtcs
Please clarify what do you try to achieve?
Why do you need to open a Gerber?
If you want to edit something in the pcb- you need to edit schematic and board files and then generate a gerber again.
