How to organize my class better
The following code works fine, but I want it to be organized differently.
It creates buttons on a 480x320 display and I have a lot of it in the class but still require too much button stuff in the share.ino.
I would like the ary[12] and buttonCount to be located in the class and somehow give share.ino access to them. That way I could move other fuctions like setInvert and StoreButtonData into the class.
I can’t figure out how to give share.ino access to the ary[12] and the buttonData. I would need to be able to do something like this from share: ary[i].invert = true; or inverted = ary[i].invert and bc = 0.
Can someone help me understand how to do that?
Share.ino
// for teensy 4.0
#include "display.h"                      // display functions, touchscreen functions anda  button class
struct ButtonData                     	// all button information is stored here
  int tSize;                                        	// the size of the text (1-5)
  int x;                                            	// x location of the button
  int y;                                            	// y location of the button
  int w;                                            	// width of the button text
  int h;                                            	// height of the button text
  int invert;                                      	// whether the button clrs are inverted (background/text)
  String text;                                   	// the button text
  int tx;                                           	// start x of the button text
  int ty;                                           	// start y of the button text
  int txClr;                                        	// the text clr
  int bgClr;                                       	// the background colot
  int bw;                                           	// total width of the button
  int bh;                                           	// total height of the button
  void (*funct)(int n);                     // the function to call if the button is pressed
  int arg;                                          	// the argument for the called function
ButtonData ary[12];
int bc = 0;
unsigned long tstart, tend;
void setup(void)
  delay(250);
  StartDisplay();                                 // start the 3.5" display
   DrawHomePage(0);
void loop(void)
  TSPoint p;
  p = GetTouch();
  if (p.z != -1)
    Press(p.x, p.y);
void Press(int x, int y)
  static int cnt = bc, dly = 750;;
  for (int i = 0; i < cnt; i++)
    if (x >= ary[i].x && x <= ary[i].x + ary[i].w)                      // search for x,y inside a button
      if (y >= ary[i].y && y <= ary[i].y + ary[i].h)
        ary[i].funct(ary[i].arg);                                       // call the button's function
        delay(dly);                                                     // this is the keypress repeat rate
        dly = 200;
        return;
  dly = 750;
void DrawHomePage(int n)
  if (n == 1)
    ClearScreen();
  Rotation(1);
  bc = 0;
  // create 5 buttons
  Button(1, 100, 50, 50, 20, false, "LAKE", WHITE, RED, Lake, 88);
  Button(2, 100, 100, 70, 25, false, "HOME", WHITE, GREEN, Home, 88);
  Button(3, 100, 150, 90, 30, false, "BASE", WHITE, BLUE, Base, 77);
  // invert all 3 buttons
  SetInvert("LAKE", true);
  SetInvert("HOME", true);
  SetInvert("BASE", true);
void Button(int tSize, int x, int y, int w, int h, boolean invert, String text, int txClr, int bgClr, void (funct)(int n), int arg)
  NewButton(tSize, x, y, w, h, invert, text, txClr, bgClr, funct, arg);   // create the button
  StoreButtonData(tSize, x, y, w, h, invert, text, txClr, bgClr, funct, arg);
  bc++;
void ReButton(int tSize, int x, int y, int w, int h, boolean invert, String text, int txClr, int bgClr, void (funct)(int n), int arg)
void StoreButtonData(int tSize, int x, int y, int w, int h, int invert, String text, int txClr, int bgClr, void (funct)(int n), int arg)
  ary[bc].tSize = tSize;
  ary[bc].x = x;
  ary[bc].y = y;
  ary[bc].invert = invert;
  ary[bc].text = text;
  ary[bc].txClr = txClr;
  ary[bc].bgClr = bgClr;
  ary[bc].w = w;
  ary[bc].h = h;
  ary[bc].funct = funct;
  ary[bc].arg = arg;                                                    // increment the button count
void SetInvert(String name, boolean tf)
  int a = 0;
  for (int i = 0; i < bc; i++)
    if (ary[i].text == name)
      ary[i].invert = tf;
      a = i;
  ReButton(ary[a].tSize, ary[a].x, ary[a].y, ary[a].w, ary[a].h, ary[a].invert, ary[a].text, ary[a].txClr, ary[a].bgClr, ary[a].funct, ary[a].arg);
void SetInvert(int id, boolean tf)
  ary[id].invert = tf;
  ReButton(ary[id].tSize, ary[id].x, ary[id].y, ary[id].w, ary[id].h, ary[id].invert, ary[id].text, ary[id].txClr, ary[id].bgClr, ary[id].funct, ary[id].arg);
void Lake(int n)
  Serial.println("Lake Pressed");
void Home(int n)
  Serial.println("Home Pressed");
void Base(int n)
  Serial.println("Base Pressed");
display.h
// display functions, touchscreen functions and a button class
#ifndef __DISPLAY_H__
#define __DISPLAY_H__
#define MISTER               // SPRINKLER or MISTER
#include <arduino.h>
#include "Adafruit_HX8357.h"                        // the 480x320 display
#include <Adafruit_GFX.h>                           // Core graphics library
#include "TouchScreen.h"                            // the touch screen
// externally visible functions
void StartDisplay();                                // start the display
TSPoint GetTouch();                                 // check for a screen touch (must be continually polled)
void Rotation(int r);                               // set the screen rotation
void ClearScreen();                                 // clears the screen
// The display uses hardware SPI, plus pins 9 & 10
#define TFT_DC_PIN            9
#define TFT_CS_PIN           10
#define TFT_RST_PIN          15                     // tie this to arduino RST if you like
// These are the four touchscreen pins
#ifdef SPRINKLER
#define YM_PIN A0                                   // (pin 14) can be a digital pin
#define XP_PIN A1                                   // (pin 15) can be a digital pin
#endif
#ifdef MISTER
#define YM_PIN 7                                    // can be a digital pin
#define XP_PIN 8                                    // can be a digital pin
#endif
#define YP_PIN A2                                   // (pin 16) must be an analog pin, use "An" notation!
#define XM_PIN A3                                   // (pin 17) must be an analog pin, use "An" notation!
#define MINPRESSURE 100                             // minimum touch pressure to recognize a touch
#define MAXPRESSURE 1000                            // maximum touch pressure to recognize a touch
// This is calibration data for the raw touch data to align the screen coordinates
#define TS_MINX 105  // bottom
#define TS_MINY  60  // right
#define TS_MAXX 945  // top
#define TS_MAXY 930  // left
// Colors
#define BACKGROUND  0xA514
#define FILL        0xAD75
#define BLACK       0x0000
#define BLUE        0x0019
#define YELLOW      0xFFE0
#define RED         0xA800
#define GREEN       0x0360
#define WHITE       0xFFFF
#define GRAY        0x9CD3
class NewButton
  private:
    // private variables
    int _tSize;                                     // the size of the text (1-5)
    int _x;                                         // x location of the button
    int _y;                                         // y location of the button
    int _w;                                         // width of the button text
    int _h;                                         // height of the button text
    boolean _invert;                                // whether the button clrs are inverted (background/text)
    String _text;                                   // the button text
    int _tx;                                        // start x of the button text
    int _ty;                                        // start y of the button text
    int _txClr;                                     // the text clr
    int _bgClr;                                     // the background colot
    void (*_funct)(int n);                          // the function to call if the button is pressed
    int _arg;                                       // the argument for the called function
  public:
    // public methods
    NewButton(int tSize, int x, int y, int w, int h, boolean invert, String text, int txClr, int bgClr, void (funct)(int n), int arg);
#endif
display.cpp
Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS_PIN, TFT_DC_PIN, TFT_RST_PIN);
TouchScreen tscr = TouchScreen(XP_PIN, YP_PIN, XM_PIN, YM_PIN, 500);
NewButton::NewButton(int tSize, int x, int y, int w, int h, boolean invert, String text, int txClr, int bgClr, void (funct)(int n), int arg)
  double charWidth[6]  = {6, 6, 12, 18, 24, 29};
  double charHeight[6] = {7, 12, 18, 24, 30, 38};
  int txtw;
  // prepare to center the text horizontally
  txtw = charWidth[tSize] * text.length();
  // save the button information
  _tSize = tSize;
  _x = x;
  _y = y;
  _w = w;
  _h = h;
  _invert = invert;
  _text = text;
  _tx = x + (_w - txtw) / 2 + 1;
  _ty = y + (_h - charHeight[tSize]) / 2 + 2;
  _txClr = txClr;
  _bgClr = bgClr;
  _funct = funct;
  _arg = arg;
  // Draw the button
  tft.drawRoundRect(_x, _y, _w, _h,  10, BLACK);                          // draw the outline clr
  if (_invert)
    tft.fillRoundRect(_x + 1, _y + 1, _w - 2, _h - 2, 10, _txClr);        // draw the fill clr inverted
    tft.fillRoundRect(_x + 1, _y + 1, _w - 2, _h - 2, 10, _bgClr);        // draw the fill clr normal
  tft.setCursor(_tx, _ty );
  if (_invert)
    tft.setTextColor(_bgClr);                                             // draw the text clr
    tft.setTextColor(_txClr);                                             // draw the text clr
  tft.setTextSize(_tSize);
  tft.print(_text);
  tft.setRotation(r);
TSPoint GetTouch()
  TSPoint p;
  int16_t sav;
  tft.setRotation(0);
  // Retrieve a point
  p = tscr.getPoint();
  if (p.z < MINPRESSURE || p.z > MAXPRESSURE)
    p.x = p.y = p.z = -1;
  // Scale it from ~0->1000 to tft.width using the calibration #'s
  p.x = map(p.x, TS_MINX, TS_MAXX, tft.width(), 0);
  p.y = map(p.y, TS_MINY, TS_MAXY, 0, tft.height());
  // swap x & y
  sav = p.x;
  p.x = p.y;
  p.y = sav;
  return p;
void ClearScreen()
  tft.setRotation(1);
  tft.fillScreen(BACKGROUND);
void StartDisplay()
  tft.begin();
  delay(200);
  Rotation(1);
One way would be to make your struct a linked-list. Include a pointer to the next element. Every time you create a new ButtonData, it gets added to the list. The class can then iterate over the list to find what it needs.
Okay, so I managed to get bc into the class and share.ino has access via Getbc(); and Setbc(int n);
So now I would still like to get ary[12] into the class and give share.ino read/write/search access?
So I managed to get this done on my own. Once I setup Getbc and Setbc to let the share program access bc, I realized I could do the same with the ary[12] stuff. Now all functions that have anything to do with button data are in the class files and there are functions to handle the in and out from share.
Nothing quite like solving your own issues :slight_smile:
Let's see how you did on your own. Post the final code.
Here are the current 3 files:
I haven't cleaned things up yet but I intend to make more of the functions in the display file actual parts of the class. Still, as is, it works pretty well.
MyDisplay.ino
// for teensy 4.0
void setup(void)
  delay(250);
  DrawHomePage(0);
void loop(void)
  TSPoint p;
  p = GetTouch();
  if (p.z != -1)
    Press(p.x, p.y);
  if (n == 1)
    ClearScreen();
  Rotation(1);
  Setbc(0);
  // create 5 buttons
  Button("home", 1, 100, 50, 50, 20, false, "LAKE", WHITE, RED, Lake, 88);
  Button("lake", 2, 100, 100, 70, 25, false, "HOME", WHITE, GREEN, Home, 88);
  Button("base", 3, 100, 150, 90, 30, false, "BASE", WHITE, BLUE, Base, 77);
  fillRoundRect(1, 1, 15, 15, 3, RED);
  drawRoundRect(1, 20, 15, 15, 3, RED);
  drawRect(1, 80, 15, 15, RED);
  fillRect(1, 100, 15, 15, RED);
  drawCircle(8, 125, 7.5, RED);
  fillCircle(8, 145, 7.5, RED);
  drawLine(1, 60, 10, 70, RED);
  setCursor(1, 40);
  setTextColor(RED);
  setTextSize(2);
  print("Hello");
  SetInvert("lake", true);
  SetInvert("home", true);
  SetInvert("base", true);
  SetInvert(0, false);
  SetInvert(1, false);
  SetInvert(2, false);
  ClearScreen();
  for (int i = 0; i < Getbc(); i++)
    ReButton(i);
  setCursor(1, 40);
  setTextColor(RED);
  setTextSize(2);
  print("Hi");
  SetInvert("lake", false);
  SetInvert("home", false);
  SetInvert("base", false);
void Lake(int n)
void Home(int n)
void Base(int n)
display.h
#include <mine.h>
int Getbc();
void Setbc(int n);
void StoreButtonData(String name, int tSize, int x, int y, int w, int h, int invert, String text, int txClr, int bgClr, void (funct)(int n), int arg);
void SetInvert(String name, boolean tf);
void SetInvert(int id, boolean tf);
void Button(String name, int tSize, int x, int y, int w, int h, boolean invert, String text, int txClr, int bgClr, void (funct)(int n), int arg);
void ReButton(int id);
void ReButton(String name);
void Press(int x, int y);
void WriteText(int tSize, int x, int y, String text, int clr);
void fillRoundRect(int x, int y, int w, int h, int radius, int clr);
void drawRect(int x, int y, int w, int h, int clr);
void fillRect(int x, int y, int w, int h, int clr);
void drawRoundRect(int x, int y, int w, int h, int radius, int clr);
void setCursor(int x, int y);
void setTextColor(int clr);
void setTextSize(int size);
void print(String);
void drawLine(int x, int y , int w, int h, int clr);
void drawCircle(int x, int y, int r, int clr);
void fillCircle(int x, int y, int r, int clr);
// Colors
#define FILL        0xAD75
#define BLUE        0x0019
#define RED         0xA800
#define GRAY        0x9CD3
  String name;
class NewButton
  private:
    String _name;
  public:
    // public methods
    NewButton(String name, int tSize, int x, int y, int w, int h, boolean invert, String text, int txClr, int bgClr, void (funct)(int n), int arg);
#endif
display.cpp
ButtonData ary[12];
int bc = 0;
NewButton::NewButton(String name, int tSize, int x, int y, int w, int h, boolean invert, String text, int txClr, int bgClr, void (funct)(int n), int arg)
  int txtw;
  _name = name;
  _tSize = tSize;
  _x = x;
  _y = y;
  _w = w;
  _h = h;
  _invert = invert;
  _text = text;
  _txClr = txClr;
  _bgClr = bgClr;
  _funct = funct;
  _arg = arg;
  // Draw the button
  if (_invert)
    tft.fillRoundRect(_x + 1, _y + 1, _w - 2, _h - 2, 10, _txClr);        // draw the fill colr inverted
    tft.fillRoundRect(_x + 1, _y + 1, _w - 2, _h - 2, 10, _bgClr);        // draw the fill color normal
  if (_invert)
    tft.setTextColor(_bgClr);                                             // draw the text color
    tft.setTextColor(_txClr);                                             // draw the text color
  tft.print(_text);
  tft.setRotation(r);
TSPoint GetTouch()
  TSPoint p;
  int sav;
  tft.setRotation(0);
  // Retrieve a point
  tft.setRotation(1);
  // swap x & y
  sav = p.x;
  p.x = p.y;
  p.y = sav;
  return p;
void ClearScreen()
  tft.setRotation(1);
void StartDisplay()
  tft.begin();
  delay(200);
  Rotation(1);
int Getbc()
  return bc;
void Setbc(int n)
  bc = n;
  ary[bc].name = name;
  ary[bc].x = x;
  ary[bc].y = y;
  ary[bc].w = w;
  ary[bc].h = h;
  NewButton(name, tSize, x, y, w, h, invert, text, txClr, bgClr, funct, arg);   // create the button
  StoreButtonData(name, tSize, x, y, w, h, invert, text, txClr, bgClr, funct, arg);
  bc++;
    if (ary[i].name == name)
      ReButton(i);
void ReButton(int i)
  NewButton(ary[i].name, ary[i].tSize, ary[i].x, ary[i].y, ary[i].w, ary[i].h, ary[i].invert, ary[i].text, ary[i].txClr, ary[i].bgClr, ary[i].funct, ary[i].arg);
      ary[i].invert = tf;
      ReButton(name);
  ReButton(id);
  static int dly = 750;;
        dly = 200;
        return;
  dly = 750;
  int cx, cy;
  // determine size of the text area and erase it
  if (tSize == 3)
    cx = text.length() * 20;
    cx = text.length() * 12;
  cy = tSize * 7;
  Rotation(1);
  tft.fillRect(x, y, cx, cy, BACKGROUND);
  // Write it
  tft.setTextColor(clr);
  tft.setTextSize(tSize);
  tft.setCursor(x, y);
  tft.print(text);
  tft.fillRoundRect(x, y, w, h, radius, clr);
  tft.drawRect(x, y, w, h, clr);
  tft.fillRect(x, y, w, h, clr);
  tft.drawRoundRect(x, y, w, h, radius, clr);
  tft.setTextSize(size);
void print(String text)
  tft.print(text);
void drawLine(int x, int y, int x1, int y1, int clr)
  tft.drawLine(x, y, x1, y1, clr);
  tft.drawCircle(x, y, r, clr);
  tft.fillCircle(x, y, r, clr);
Dynamically allocated memory, isn't that best avoided on Arduino?
I'm not certain what dynamically allocated memory is of what part of the code is doing it. All I can say is this runs on a Teensy 4.0 and that little device has a lot of memory.
Sorry, my question was about @blh64 suggestion of a linked-list.
Usually for AVR chips but not for the Teensy. After all, context matters :slight_smile:
Cool. Nice to pick up something new :slightly_smiling_face:
