I have:
esp 32 s3 devkit c1, display ili 9341.
Gif is displayed only with the help of the bb_spi_lcd library. When trying to display with TFT_espi, the following appears in the serial monitor: "Guru Meditation Error: Core 1 panic'ed (StoreProhibited). Exception was unhandled".
And at the same time the frame rate is low, flickering is very visible.
I installed: PSRAM: OPI SRAM, flash mode: QUO (120MHZ), FLASH SIZE-16 MB
How to increase frame rate?
Sketch:
``` // ESP32-S3 BLE GIF Receiver
#include <bb_spi_lcd.h> // Install this library with the Arduino IDE Library Manager
#include <SPI.h>
#include <FS.h>
#include <SD.h>
#include <TFT_eSPI.h> // Include TFT library
#include <AnimatedGIF.h> // Include GIF library
#include <NimBLEDevice.h>
#include <NimBLEServer.h>
#include <NimBLEUtils.h>
#define TFT_CS 10 // 10 or 34 (FSPI CS0)
#define TFT_MOSI 11 // 11 or 35 (FSPI D)
#define TFT_SCLK 12 // 12 or 36 (FSPI CLK)
#define TFT_MISO 13 // 13 or 37 (FSPI Q)
// Use pins in range 0-31
#define TFT_DC 7
#define TFT_RST 6
// define HSPI pins
#define HSPI_MISO 37//27
#define HSPI_MOSI 35//13
#define HSPI_SCLK 36//14
#define HSPI_SS 39//26
#define LED_PIN 3 // Built-in LED on most ESP32 boards
#define SD_CS 39 // SD card CS pin
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#include "holo.h"
BB_SPI_LCD tft; // Main object for the display driver
AnimatedGIF gif; // Create AnimatedGIF object
// GIF to display
#define GifData holo // Change image to display (image name in gif_files\[image header file].h)
tft.begin(LCD_ILI9341, FLAGS_NONE, 50000000, 10, 7, 6, 3, 13, 11, 12); //
tft.setRotation(LCD_ORIENTATION_90); // Make sure you have the right orientation based on your GIF
// or the GIF will show incorrectly, even garbage output
// Values : LCD_ORIENTATION_0, LCD_ORIENTATION_90, LCD_ORIENTATION_180 or LCD_ORIENTATION_270
tft.fillScreen(TFT_BLACK);
AnimatedGIF *gif;
gif = openGif((uint8_t *)GifData, sizeof(GifData));
if (gif == NULL)
Serial.println("Cannot open GIF");
while (true)
// no need to continue
while (true)
gif->playFrame(false, NULL);
delay(1);
// Open Gif and allocate memory
AnimatedGIF *openGif(uint8_t *gifdata, size_t gifsize)
AnimatedGIF *gif;
gif = (AnimatedGIF *)malloc(sizeof(AnimatedGIF));
if (gif == NULL)
Serial.println("Not RAM Enough memory for GIF structure");
return NULL;
gif->begin(GIF_PALETTE_RGB565_BE); // Set the cooked output type we want (compatible with SPI LCDs)
if (gif->open(gifdata, gifsize, GIFDraw))
Serial.printf("Successfully opened GIF; Canvas size = %d x %d\n", gif->getCanvasWidth(), gif->getCanvasHeight());
Serial.printf("GIF memory size is %ld (%2.2f MB)", gifsize, (float)gifsize / (1024 * 1024));
gif->setDrawType(GIF_DRAW_COOKED); // We want the Animated GIF library to generate ready-made pixels
if (gif->allocFrameBuf(GIFAlloc) != GIF_SUCCESS)
Serial.println("Not Enough RAM memory for frame buffer");
return NULL;
return gif;
printGifErrorMessage(gif->getLastError());
return NULL;
// The memory management functions are needed to keep operating system
// dependencies out of the core library code
// memory allocation callback function
void *GIFAlloc(uint32_t u32Size)
return malloc(u32Size);
} /* GIFAlloc() */
// memory free callback function
void GIFFree(void *p)
free(p);
// Draw callback from the AnimatedGIF decoder
void GIFDraw(GIFDRAW *pDraw)
if (pDraw->y == 0)
{ // set the memory window (once per frame) when the first line is rendered
tft.setAddrWindow(pDraw->iX, pDraw->iY, pDraw->iWidth, pDraw->iHeight);
// For all other lines, just push the pixels to the display. We requested 'COOKED'big-endian RGB565 and
tft.pushPixels((uint16_t *)pDraw->pPixels, pDraw->iWidth);
// Get human-readable error related to GIF
void printGifErrorMessage(int errorCode){
switch (errorCode){
case GIF_DECODE_ERROR:
Serial.println("GIF Decoding Error");
case GIF_TOO_WIDE:
Serial.println("GIF Too Wide");
case GIF_INVALID_PARAMETER:
Serial.println("Invalid Parameter for gif open");
case GIF_UNSUPPORTED_FEATURE:
Serial.println("Unsupported feature in GIF");
case GIF_FILE_NOT_OPEN:
Serial.println("GIF File not open");
case GIF_EARLY_EOF:
Serial.println("GIF early end of file");
case GIF_EMPTY_FRAME:
Serial.println("GIF with empty frame");
case GIF_BAD_FILE:
Serial.println("GIF bad file");
case GIF_ERROR_MEMORY:
Serial.println("GIF memory Error");
default:
Serial.println("Unknown Error");
UPD:
I tried other gifs. They display better, but is it possible to improve the display quality on the display?
