How to output waveform to servo
The problem with this idea is that a servo does not move at a constant rate. The whole point of a servo is that it starts off fast and as it approaches the required point it slows down. Therefore it will not do what you want, unless you want to move the plate very much slower than the servo can respond. It that is the case then just move the servo at a constant rate of degrees per unit time. No need to calculate anything else.
