How to pass a function from a class to a structure
struct Command
    char const *text;
    void (*f)(void);
    bool active;
/* enumeration of objects - commands */
Command commands[]
    {"clearcom", clearCommandTerminal, false},
    {"dectop", desctop, true},
    {"deepsleep", powerSaveDeepSleep, true},
    {"systray", systemTray, true},
    {"app_desctop", _desc.window("f"), true}
I can't convey this _desc.window("f")
Tell me the solution. This code that I have given is located in the library file (ex.cpp), this library will be used by the user.
How to implement a mechanism so that the user can add his own function to the array?
What platform? If it's not an AVR, you can put a std::function in the struct. That can then accept a std::bind or a lambda.
