How to pass a function name into a library
Hi Guys,
i am working into a small project (library) that will configure the interrupt to call a function at every X millisecond that you want.
i got the librarie working, the class, the include part all going well.
BUT...:wink:
i got jam in the part that i need to send the function name to the interrupt routine.
right now the call is TimeCall.go(millisecond); and i would like it to be TimeCall.go(function, millisecond) and to get the ISR to call that function.
Right now i do a digital write (toggle) as a proof of concept but this is where i would like to insert the function call that TimeCall.go would have send.
Does anyone could pin point how to do that?
Thanks in advance.
Here is all my working code
#include <TimeCall.h>
// #include <avr/interrupt.h>
#include <avr/io.h>
TimeCall montime;
  montime.go(100); // This will make a interrupt a every 100ms
TimeCall.h - Library for calling a function at an interval time interrupt
Created by Patgadget, October 2, 2010
Released into the public domain
#ifndef TimeCall_h
#define TimeCall_h
#include "WProgram.h"
class TimeCall
  public:
      void go(uint16_t millisecond );
  private:
    int _variable;
#endif
  TimeCall.cpp - Library for calling a function at an interval time interrupt
volatile int32_t int_counter;
volatile uint16_t internal_millisecond;
void TimeCall::go(uint16_t millisecond)
  internal_millisecond = millisecond;
  //Timer2 Settings: Timer Prescaler /64,
  TCCR2B = 0;
  TCCR2A = 0;
  TCCR2B |= (1<<CS22);
  TCCR2B &= ~(1<<CS21);
  TCCR2B &= ~(1<<CS20);
  // Use normal mode
  TCCR2A &= ~((1<<WGM21) | (1<<WGM20));
  TCCR2B &= ~(1<<WGM22);
  // Use internal clock - external clock not used in Arduino
  ASSR |= (0<<AS2);
   //Timer2 Overflow Interrupt Enable
  TIMSK2 |= (1<<TOIE2);
  TIMSK2 &= ~((1<<OCIE2B) | (1<<OCIE2B));
  TCNT2 = 6;
ISR(TIMER2_OVF_vect) {
  TCNT2 = 6;
  int_counter += 1;
  if (int_counter == internal_millisecond) {
    int_counter = 0;
    digitalWrite(13,1-digitalRead(13));  // THIS IS WHAT i want to replace with a function call
Sounds like you need a "pointer to a function". I prefer typedefs...
typedef void (*TCallThisEvery)( void );
void MyCallback( void )
  montime.go(100, MyCallback); // This will make a interrupt a every 100ms
class TimeCall
  public:
    void go(uint16_t millisecond, TCallThisEvery callthis );
  private:
    TCallThisEvery _callthis;
void TimeCall::go(uint16_t millisecond, TCallThisEvery callthis)
  _callthis = callthis;  // This must be done before the ISR could be called
    _callthis();
Thanks a lot Coding Badly,
Almost work like a charm,
got a small last question,
This compile:
But this does not?
   _callthis();
the _callthis is not reconize in the ISR, could it be becose the ISR is not part of the TimeCall class?
i figure a way around it by defining a global variable in the .cpp file,
is that ok?
Thanks for your help.
Patgadget
You have an instance of the TimeCall class, right? The _callback member is a field in that class. So, you need to call the function using myTimeClassInstance._callback() (assuming that _callback is public. If not, you'll need to add a method to return the pointer to the function (_callback)).
Well i did not get this to well PaulS, i am more of a Hardware guy than software,
so this is was is working now:
TimeCall timecall;
  timecall.go(toogle, 15);
void toogle()
  digitalWrite(13,(1-digitalRead(13)));
#ifndef TimeCall_h
#define TimeCall_h
class TimeCall
  public:
      void go(TCallThisEvery callthis,uint16_t millisecond );
#endif
volatile TCallThisEvery _callthis;
void TimeCall::go(TCallThisEvery callthis,uint16_t millisecond)
  TCCR2B = 0;
  TCCR2A = 0;
  // Use normal mode
  ASSR |= (0<<AS2);
  TCNT2 = 6;
  TCNT2 = 6;
  int_counter += 1;
    int_counter = 0;
      _callthis();
And this is what is not working!
TimeCall timecall;
void toogle()
#ifndef TimeCall_h
#define TimeCall_h
class TimeCall
  public:
  private:
    TCallThisEvery _callthis; // NOTE THE PRIVATE DECLARATION HERE <<<<<<<<
#endif
//volatile TCallThisEvery _callthis;     // NO MORE DECLARATION HERE <<<<<<
  TCCR2B = 0;
  TCCR2A = 0;
  // Use normal mode
  ASSR |= (0<<AS2);
  TCNT2 = 6;
  TCNT2 = 6;
  int_counter += 1;
    int_counter = 0;
      _callthis();
Could you explain what should be add?
Thanks
Patgadget
But this does not?
Yikes! Sorry about that.
Exactly.
i figure a way around it by defining a global variable in the .cpp file, is that ok?
Yes.
PaulS's suggestion will work as well.
Do you want the full explanation (e.g. why my code didn't compile and what choices are available) or do you want the short, just-get-it-working version?
Well,
the short one if it is ok like that i will keep it working that way
Thanks a lot for all your help
Patgadget
BTW you could use this librairie now as it is working (the top one) :wink:
Private instance data (like _callthis) is only accessible in a method call of the class where the data is declared.
How's that for short? :smiley:
