How to pass a String to a Char Pointer
Hello, I need to pass two string variables (router, pws) to two char pointer variables (ssid, assword), I am using this code:
char* ssid = "";
char* password = "";
String router = "ThisMyRouter";
String psw = "12345678";
int str_len;
  str_len = router.length() + 1;
  ssid[str_len];
  router.toCharArray(ssid, str_len);
  Serial.println(ssid);
  str_len = psw.length() + 1;
  password[str_len];
  psw.toCharArray(password, str_len);
  Serial.println(password);
void loop() {}
but it does not run correctly, the data is repeated:
ThisMyRouter
ThisMyRouter12345678
12345678
Someone could tell me how to solve this?
Tell us what you need to do, not how you think you ought to do it
Those two pointers are pointing to static data with no memory allocated
Try
char ssid[33];
char pwd[64];
Then you have SRAM to store your information
But if you only need the cString pointer of your Strings, use router.c_str() and psw.c_str()
No, that's how you think you need to do what you want to do.
(And they're Strings, not strings. I believe I've already hinted this)
This line
ssid[str_len];
does absolutely nothing.
This might work
ssid = (char *) malloc(str_len);
I hope that fixed it for you. But even if it does, I think this is probably not the right or best way to do it. It feels pointless. But I can't be sure.
You have asked what is called an "X-Y" question. You want do to X and you think you need to do Y to achieve it, but you can't make Y work. So you ask the forum how to fix Y.
But if you ask the forum how to achieve X, there might be an easy way that does not require Y to be done at all!
Forgetting the code I have posted, what is the best way to pass a String variable to a pointer?
.c_str()
You could pass a pointer to the actual char array in the String, but there is no way to actually pass a String to a pointer, a pointer just points to something else, it cannot contain any actual data itself. You also need to be careful setting a pointer to anything having to do with a String, because Strings tend to get dynamically moved around in memory if you start manipulating them.
You can store the String in a char array, then set a pointer to point to that char array, but then why not just store the text in a char array to begin with.
Forgetting the code that you have posted, why do you need to do it ? Where does the String come from and could it be a C style string instead ?
I am trying to implement a web server with ESP8266, here are the parameters: ssid and password are defined as char*:
char* ssid = "your-ssid"
char* password = "your-password"
but I need to change this data, programmatically within my code, I get this data from the serial port in the form of strings, hence my need to pass from strings to pointers
I think you mean that you get the data as Strings, but of course you don't have to, you could get them as pointers to C style strings if you wanted to
Could you please give me an example?
Start here
