Hi all, i have this project running with a WEMOS D1 R1 Webserver with a fingerprint scanner. I wanted to pass some INT data from a seperated enroll header file to main file to run it in the loop().
What i did was i create a global.h with a variable (int enrollId) then i want to save it from enroll.h and pass the variable to main. But the variable is empty when i run it.
Below are 3 code section, Page_Enroll.h, main and global.h
This is my Page_Enroll.h code here i pass my input to id variable and assign to enrollId variable
const char PAGE_Enrollfingerprint[] PROGMEM = R"=====(
<meta name="viewport" content="width=device-width, initial-scale=1" />
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<a href="admin.html" class="btn btn--s"><</a> <strong>Enroll fingerprint</strong>
<body><h1>Enroll fingerprint</h1>
<p>Status - </p><p id="outputState"></p>
<p>result - </p><p id="result"></p>
<p>Please enter an ID to enroll fingerprint:</p>
ID: <input type="text" id="myid" name="id">
<input type="submit" value="Submit" onclick="Trigger()">
<p><a href="javascript:Trigger()"><button class="fingerbutton">Start Enroll</button></a></p>
<script>
function Trigger()
setValues("/admin/enroll");
int id = parseInt(document.getElementById("myid").value);
if(document.getElementById('myid').value == "")
document.getElementById('result').innerHTML = id;
document.getElementById('outputState').innerHTML = "Cannot be empty";
else if(document.getElementById('myid').value != "")
enrollId = id;
document.getElementById('result').innerHTML = enrollId;
document.getElementById('outputState').innerHTML = "ready to enroll!";
server.send(200,"text/html,",document.getElementById('result'));
window.onload = function ()
load("style.css","css", function()
load("microajax.js","js", function()
// Do something after load...
function load(e,t,n){if("js"==t){var a=document.createElement("script");a.src=e,a.type="text/javascript",a.async=!1,a.onload=function(){n()},document.getElementsByTagName("head")[0].appendChild(a)}else if("css"==t){var a=document.createElement("link");a.href=e,a.rel="stylesheet",a.type="text/css",a.async=!1,a.onload=function(){n()},document.getElementsByTagName("head")[0].appendChild(a)}}
</script>
This is part of the global.h code
#ifndef GLOBAL_H
#define GLOBAL_H
int enrollId;
boolean enableEnrollFinger = false;
#endif
This one part of my Main code (run_enroll() is the place that i find my enrollid variable is not working)
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <Ticker.h>
#include <EEPROM.h>
#include <WiFiUdp.h>
#include "global.h"
#include "Page_Enroll.h"
server.on ("/enroll.html", []() { server.send ( 200, "text/html", PAGE_Enrollfingerprint ); } );
server.on ("/admin/enroll", run_enroll);
server.onNotFound ( []() { Serial.println("Page Not Found"); server.send ( 400, "text/html", "Page not Found" ); } );
server.begin();
if(enableEnrollFinger)
run_enroll();
delay(2000);
server.handleClient();
void run_enroll()
enableEnrollFinger = true;
Serial.println("Ready to enroll a fingerprint!");
Serial.println(enrollId);
Serial.println(startenrolling);
id = enrollId;
if (id == 0) {// ID #0 not allowed, try again!
Serial.println("fail to enroll!");
return ;
Serial.print("Enrolling ID #");
Serial.println(id);
while (! getFingerprintEnroll() );
