How to pause & continue led sequence with button press
I understand being confused, I get confused, too with "millis()". There is no "right" way to do this, but some methods are preferred. The more you tinker with it, the more you will understand. Here is my spin on "blink without delay" that you can plug into WOKWI.COM for testing. The LED_BUILTIN blinks all the time UTIL the button is pressed, and the LED pauses in the state it was in UNTIL the button is released. The Serial Monitor also shows the state of the LED.
sketch.ino
unsigned long newMillis = 0, oldMillis = 0; // event timers
unsigned long interval = 500; // milliseconds
bool state; // the state of the LED
byte buttonPin = 2; // button pin
  Serial.begin(115200); // configure Serial Monitor baud
  pinMode(LED_BUILTIN, OUTPUT); // configure LED_BUILTIN/DIO pin 13 as OUTPUT
  pinMode(buttonPin, INPUT_PULLUP); // configure button pin as INPUT with internal pullup resistor
  blink(); // call the "blink" function
void blink() {
  newMillis = millis(); // start an event
  if (newMillis - oldMillis > interval) { // compare difference in event times to interval
    oldMillis = newMillis; // store the new event start time
    state = !state; // flip the current state for the LED
    digitalWrite(LED_BUILTIN, state); // set the LED to the current state
    if (state) Serial.print("1"); // show current state in Serial Monitor
    else Serial.print("0"); // show current state in Serial Monitor
  while (!digitalRead(buttonPin)) {} // hold here while button is pressed
diagram.json
  "version": 1,
  "author": "Anonymous maker",
  "editor": "wokwi",
  "parts": [
    { "type": "wokwi-arduino-nano", "id": "nano", "top": -110.4, "left": 201.1, "attrs": {} },
      "type": "wokwi-pushbutton-6mm",
      "id": "btn1",
      "top": -136.6,
      "left": 336,
      "attrs": { "color": "green" }
      "type": "wokwi-text",
      "id": "text1",
      "top": -163.2,
      "left": 326.4,
      "attrs": { "text": "pause" }
  "connections": [ [ "nano:GND.2", "btn1:2.l", "black", [ "v0" ] ], [ "nano:2", "btn1:1.l", "green", [ "v0" ] ] ],
  "dependencies": {}
