Hello,
I’m working on countdown timer.
Timer should work while ‘‘button1’’ is HIGH. But somehow the loop runs even if ‘‘button1’’ is LOW
Any sugestions where I’m making mistakes with code?
Thanks in advance!
Code is added bellow.
#define numberOfSeconds(_time_) ((_time_ / 1000) % 60)
#define numberOfMinutes(_time_) (((_time_ / 1000) / 60) % 60)
// INCLUDES
// https://github.com/avishorp/TM1637
#include <TM1637Display.h>
// CONSTANTS
const uint8_t OFF[] = {0, 0, 0, 0};
// In this library, the byte order is .GFEDCBA
const uint8_t PLAY[] = {B01110011, B00111000, B01011111, B01101110};
byte oneChanOut = 5; // Channel output pin
int brightness1 = 0; // Initial length of tube 1
int fadeAmount1 = 1; // Increment between refreshes
int buttonPin = 9;
int Button1;
// GLOBALS
// Create a display object, specifying parameters (Clock pin, Data pin)
TM1637Display display(2, 3);
// 1000ms in 1sec, 60secs in 1min, 60mins in 1hr. So, 1000x60x60 = 3600000ms = 1hr
unsigned long timeLimit = 3600000;
void setup(){
// Set brightness
display.setBrightness(0x0c);
// Clear the display
display.setSegments(OFF);
pinMode(buttonPin, INPUT);
void loop () {
int button1 = digitalRead(buttonPin);
while (button1 == HIGH){
countdown();
if (button1 == LOW){
int seconds = numberOfSeconds(timeLimit);
int minutes = numberOfMinutes(timeLimit);
// This displays the seconds in the last two places
display.showNumberDecEx(seconds, 0, true, 2, 2);
// Display the minutes in the first two places, with colon
display.showNumberDecEx(minutes, 0x80>>3, true, 2, 0);
void countdown() {
// Calculate the time remaining
unsigned long timeRemaining = timeLimit - millis();
// get the button state on the input
while(timeRemaining > 0) {
// To display the countdown in mm:ss format, separate the parts
int seconds = numberOfSeconds(timeRemaining);
int minutes = numberOfMinutes(timeRemaining);
// Update the time remaining
if(millis() < timeLimit)
fadeAmount1 = ((timeLimit - timeRemaining)/140062);
brightness1 = ((timeLimit - timeRemaining)/14062);
analogWrite(oneChanOut, brightness1);
void displayText() {
display.setSegments(PLAY);
delay(2000);
