Iʻm busy with a project with a couple of thousand lines of code.
Iʻm certainly NOT a wizard with C++ and got bitten by a stupid bug of my own making.
A line of code was typed a == b + c ;
instead of a = b + c ;
The code compiled and ran without errors being noted, and that code wasn't tested immediately. When the bug did show up, it took me far longer than necessary.
I was very surprised the compiler didn't pick up a comparison operator being used outside of a comparison instruction. Neither the v1.8.19 and v2.3.4 IDEʻs pick up the error.
Are there any compiler settings to enable catching future errors and saving tons of time.
volatile int a = 2, b = 3, c = 5; // volatile to avoid compiler optimization
a == b + c ;
Serial.println(a);
void loop() {}
in the IDE preferences I validated the checkbox to give me all compiler warnings and got
sketch_feb24a.ino:4:5: warning: value computed is not used [-Wunused-value]
a == b + c ;
Unfortunately, it's valid C++ syntax, and not an error.
As well as tuning on all compiler warnings, I would recommend using cppcheck https://cppcheck.sourceforge.io/, although it can be awkward to run with Arduino sketches. I generally copy the .ino file to a .cpp.
Hi Bob, Thanks for the reply and explanation that my error is valid syntax.
I see that now. Catching all the warnings are now enabled.
My old eyes must be getting tired.
BTW, has nothing to do with which IDE you use, the fancy IDE is just a GUI over the command line.
I did stumble across a lint, but I have not had the time or motivation to play with it since I only play with code these days.
If I knew I was prone to that error, occasionally cranking the warning level to max is what I do, and I also use the IDE2 (only) find in all files feature (with grep) if I am looking for something specific.
Excellent question. At maximum you will get a lot of unimportant messages including from libraries. I am 83 and do not have a lot of extra time to chase those messages. I am also only a hobbyist now after 50+ years of a paid code slinger so I have an excellent 'sense' of when I need to crank up the volume.
For new folks it is a bit of a problem. If they crank up the level, they may become accustomed to seeing a lot of unimportant messages and fall into the trap of not reading carefully so that they miss an important message.
Perhaps the most common example of this situation is the misuse of the comparison operator. What I mean is the coder entered if a = 0 {...} instead of if a == 0. This can be 'caught' by simply writing ALL such code in the form of if 0 = a (caught). if 0 == a (correct)
Whether the warning messages are important or not depends on the context and intentions of the programmer. I work with full warnings turned on and I am always aware that warning are being reported as they flash by during compilation. I normally only look at them in detail if the sketch does not behave as expected and I usually try to eliminate as many warnings as possible, even if they are irrelevant, during the late stages of a project. I agree that warnings caused by library code are a particular nuisance and I do not usually try to eliminate them as long as I am convinced that the subject of the warning is causing no problem. I do, however, seek to understand such warnings and interpret what they are telling me.
Whist that does the job, I cannot begin to tell you how much I dislike that form of comparison.
At heart I am a simple soul and like to read my code much as I would an essay and if 0 = a does not fit that model. When I see it used I always have to stop and think what is being tested (perhaps not such a bad thing !) as it jars with me as it is not a form that fits normal English usage and I have never used it in code that I write. Sorry, but it is not for me.
It may be different for users whose native language is not English. Take for instance the English way of adding an adjective to a noun such as red car. If I saw car red in an English text I might stop and work out what it meant but a native French speaker would probably not even notice
Truth be told I also do not write my code that way (if 0 = a) but I teach both and the reason why. I can probably count on one hand the number of times I have misused = for == in 50+ years of coding but maybe I am different.
TOTALLY agree, re importance of each compiler message. At IBM I saved the company hours of nightly runtime by simply making a small source code change that only showed up as an I (informational) level message and the stock compile command cut off at one level higher. I didn't put that in as an official suggestion, if I had I would have been able to retire earlier.
