How to Play an Audio using Arduino Uno
I'm using a 8 ohms 1 watt speaker, MicroSD card adapter, and SD card
here is one of the code I used
#include "SD.h"
#define SD_ChipSelectPin 10
#include "TMRpcm.h"
#include "SPI.h"
TMRpcm tmrpcm;
tmrpcm.speakerPin=9;
if(!SD.begin(SD_ChipSelectPin))
  Serial.println("SD fail");
  return;
tmrpcm.setVolume(6);
tmrpcm.play("test.wav");
SC to pin 10
SCK to pin 13
MOSI to pin 11
MISO to pin 12
VCC to 5v
GND to GND
positive speaker pin to 9
negative speaker pin to GND
Show a diagram. Describe what you observe.
  • You cannot drive a speaker with a GPIO pin.
not that one anyway. You need either an amplifier - if you want 1W out; or a
piezo speaker like this - but it will be quiet.
30mm Piezo Transducer 150mm Leads — Switch Electronics | Your One Stop Component Shop?
