can friends help me.
I just want to play the kick drum & crash sound from the default sound of an electric keyboard (Roland/Korg) via the keyboard's MIDI input port which is controlled by Arduino.... and I just want to play the two sounds simultaneously via one switch button... ..How to ?
Thank You .
You should never post in the Uncategorised section.
It says so in the description of the section. Therefore I have moved your post here.
You might want to look at this How to get the best out of this forum before you proceed any further.
We only know what you tell us, and without knowing what you have, we don't stand a chance.
So:-
What Arduino do you have?
How is it wired up? Schematic please. Hand drawn is fine, but Fritzing or pictures joined with lines is not.
Please post your best attempt at your code, and don't forget to use code tags, like that link told you how to do.
But it is quite simple just sent two MIDI Note On messages when the button is pressed, and two MIDI Note Off messages when it is released.
