Hello. I want to play different sound by push button, so 1 button can play 1 sound. When i'm trying, I only got random noises (sounds like speaker storing). I don't know what to do anymore with this code, I hope somebody can help to solve this. Thanks
this is what happen with this code DFPlayer - YouTube
#include <Servo.h>
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
Servo servo6;
int pushPin1 = 7;
int button1Reading = 0;
int pushPin2 = 6;
int button2Reading = 0;
int pushPin3 = 5;
int button3Reading = 0;
int pushPin4 = 4;
int button4Reading = 0;
int pushPin5 = A2;
int button5Reading = 0;
int pushPin6 = A3;
int button6Reading = 0;
// Use pins 2 and 3 to communicate with DFPlayer Mini
static const uint8_t PIN_MP3_TX = 2 ; // Connects to module's RX
static const uint8_t PIN_MP3_RX = 3; // Connects to module's TX
SoftwareSerial softwareSerial(PIN_MP3_RX, PIN_MP3_TX);
// Create the Player object
DFRobotDFPlayerMini player;
pinMode(pushPin1, INPUT_PULLUP);
pinMode(pushPin2, INPUT_PULLUP);
pinMode(pushPin3, INPUT_PULLUP);
pinMode(pushPin4, INPUT_PULLUP);
pinMode(pushPin5, INPUT_PULLUP);
pinMode(pushPin6, INPUT_PULLUP);
servo1.attach(13);
servo2.attach(12);
servo3.attach(11);
servo4.attach(10);
servo5.attach(9);
servo6.attach(8);
servo1.attach(13);
servo2.attach(12);
servo3.attach(11);
servo4.attach(10);
servo5.attach(9);
servo6.attach(8);
// Init USB serial port for debugging
// Init serial port for DFPlayer Mini
softwareSerial.begin(9600);
// Start communication with DFPlayer Mini
if (player.begin(softwareSerial)) {
Serial.println("OK");
// Set volume to maximum (0 to 30).
player.volume(30);
Serial.println("Connecting to DFPlayer Mini failed!");
//softwareSerial.begin(9600);
button1Reading = digitalRead(pushPin1);
if (button1Reading == LOW)
//the first button has been pushed and the first servo turns 180 degrees
servo1.write(0);
player.stop();
//the first button has been pushed again and the first servo turns back 180 degrees
servo1.write(115);
player.play(1);
button2Reading = digitalRead(pushPin2);
if (button2Reading == LOW)
servo2.write(0);
player.stop();
servo2.write(180);
player.play(2);
button3Reading = digitalRead(pushPin3);
if (button3Reading == LOW)
servo3.write(0);
player.stop();
servo3.write(0);
player.stop();
servo3.write(180);
player.play(3);
button4Reading = digitalRead(pushPin4);
if (button4Reading == LOW)
servo4.write(0);
player.stop();
// startPlayback(guru, sizeof(guru));
servo4.write(180);
player.play(4);
button5Reading = digitalRead(pushPin5);
if (button5Reading == LOW)
servo5.write(0);
player.stop();
servo5.write(180);
player.play(5);
button6Reading = digitalRead(pushPin6);
if (button6Reading == LOW)
servo6.write(0);
player.stop();
servo6.write(180);
player.play(6);
