How to power external LED's
I am looking at a project in which I'll need to more power to drive LEDs than the Uno 5v can supply. I can see getting an external power supply and a barrel jack receptacle to power the LEDs, but do I still need a separate power supply for the Uno itself? Or can I jumper the positive line from the external supply to VIN? Is there a standard way to accomplish this?
Depends on the power supply. If it is a 5V supply then you can power the Uno through its 5V pin - not Vin which needs a minimum of 6.5V. You will also need to connect the power supply negative to Uno GND.
Steve
Thanks. Is using VIN ok if the supply is at least 6.5v?
According to the general specifications for the Arduino Uno R3, power can be supplied from any of the following:
  • USB
  • 9 V DC jack
  • Vin pin (7-12 V)
It is my understanding that the jack and Vin pins are tied together, so 7-12 V supplied to either should work.
Thanks.
Where do I find this specification?
Look at the Power section under the FAQ tab for the Arduino Uno Rev3 within the Arduino Store.
woolsey:
Not quite, they are linked by a diode, so that >6.75V will work for Vin but the jack needs more like 7.5V. The diode
prevents damage if the wrong polarity power plug is inserted. The schematic for Arduinos are open-source.
