How to prevent trigger multiple relays at once?
I have a 4 channel relay module and i want to prevent to trigger if there is an already triggered channel.
So i tried something but it’s not working.
void callback(char* topic, byte* payload, unsigned int length) {
  String any_relay = "";
  if (payload[0] == '1')
     for (uint8_t i = 0; i < RELAY_NUM; i++)
        if(any_relay == "")
        Serial.print("Relay #");
        Serial.print(i+1);
        Serial.println(" OPENED!");
        digitalWrite(relay[i], ON);
        any_relay = topic;
          Serial.println("Need to close the other relay channel before to open a new one! : " + any_relay);
I can see the any_relay variable is changing to the name of last opened relay channel(as a A,B,C,D) but i think there is a problem with comparison but im not sure.
        if(any_relay == "")
So, any_relay is unconditionally set to “” and then you test whether it is set to “”. Is that what you meant to do ?
UKHeliBob:
if (payload[0] == ‘1’)
        if(any_relay == “”)
So, any_relay is unconditionally set to "" and then you test whether it is set to "". Is that what you meant to do ?
If it’s equal value it means there is no triggered relay already and i assign the topic value to any_relay variable ,inside of the if statement. So i expect that i couldn’t trigger other relay because any_relay variable changed(not equal to “”).
OK, I see now, but it reinforces why I always put code blocks for if, for, while in braces as it makes clear which code is executed
UKHeliBob:
So do you know why it's not working ?
Please post the whole program
I see an anomaly in what you have posted
On the first pass through the for loop any_relay will always equal "" so
        if(any_relay == "") will always be true.
If I interpret the code correctly then this will cause relay 1 to turn on. Have I interpreted the code correctly ?
