How to print in Lcd a letter using the letter Ascii value in code
Hi, I have this code:
int digits[5] = {'0','A', 'B', 'C', 'D'}; int i;
Serial.begin(9600); }
Serial.print(" "); Serial.print(digits*);* delay(2000); i++; * if(i > 4)* * {* * i = 0;* * }* } This code is supposed to print the Characters inside the "digits" array in the serial monitor, although I am reading only the ASCII values from the array, how can I print the characters instead of their Ascii values?
F1_: This code is supposed to print the Characters inside the "digits" array in the serial monitor, although I am reading only the ASCII values from the array, how can I print the characters instead of their Ascii values?
if you null-terminate them as a char array instead:
char digits[] = {'0','A', 'B', 'C', 'D', '\0'};
int i;
 Serial.print(" ");
 Serial.print(digits);
 delay(2000);
 i++;
  if(i > 4)
    i = 0;
Nice, thank you very much BulldogLowell!! :D
