How to print return data without serial.print?
I can’t use serial.print because it conflict with my unique serial communication.
but I want to know the return value of my function “SPI_Transfer” and print it on the PC screen just like C language.
How can I do that?
Thanks.
/* Fake SPI Initialise Function Based on UART. NOT the SPI Library in the Arduino System */
void SPI_Initialise() {
  pinMode(DCLpin,OUTPUT); // MOSI: Camera to Lens
  pinMode(LCLKpin,OUTPUT); // LCLK pin
  pinMode(SSpin,OUTPUT); // SS pin
  pinMode(DLCpin,INPUT); // MISO: Lens to Camera
  //Set UART as SPI.
  UBRR0 = 0;
  UCSR0C = (1<<UMSEL01)|(1<<UMSEL00)|(1<<UCPHA0)|(1<<UCPOL0);  //Set to MasterSPI (UMSEL0=1, UMSEL1=1), in Mode3 (CPHA=1, CPOL=1)
  UCSR0B = (1<<RXEN0)|(1<<TXEN0); //Enable TX and RX (TX = MOSI, RX = MISO)
/* clock rate: UBRR0 = (FCPU/(2*BAUD)) -1;
for 62.5kHz or 16us pulse, UBRR0 = (16000000/(2*62500))-1 = 127;
for 76.9kHz or 13us pulse, UBRR0 = (16000000/(2*76900))-1 = 103;
  UBRR0 = 127;
/* Fake SPI Protocol Function Based on UART. NOT the SPI Library in the Arduino System */
byte SPI_Transfer(byte data) {
  /* Wait for empty transmit buffer */
  while ( !( UCSR0A & (1<<UDRE0)) );
  /* Put data into buffer, sends the data */
  UDR0 = data;
  /* Wait for data to be received */
  while ( !(UCSR0A & (1<<RXC0)) );
  /* Get and return received data from buffer */
  return UDR0;
1st function will be in the void setup()
2nd function will be used in the void loop()
these are the unique serial communication. when I tried using Serial.print, it will conflict with my serial function.
Software serial and a TTL to RS232 / USB converter.
SoftwareSerial - serial to usb converter - computer = hyperterminal or similar program.
jenaflex: I can't use serial.print because it conflict with my unique serial communication.
You probably need to explain what your "unique serial communication" is before anyone can give you a meaningful answer.
  //Set UART as SPI.
  UBRR0 = 0;
  UBRR0 = 127;
  UDR0 = data;
  return UDR0;
It is not terribly helpful not posting all the code.
What you meant to say was “I am using the hardware UART for generating another SPI interface”, although why I don’t know because several devices can be chained on the hardware SPI interface.
So the answer remains what I said in #1, and what cyclegadget said in #2
