How to print serial info on separate lines?
I can get the code to print the result of counter on screen using Serial.print ()
And can also print it with a tab between each line by using ("\t")
But what do I type to print it on a separate line every time?
Thanks! :)
Serial.println()
i dont think \n works but you could try
Have you tried using Serial.println()
yes, use Serial.println()
Here is the Reference:
http://arduino.cc/en/Serial/Println
Lefty
Brilliant, thanks all, the Serial.println() was the answer. Cheers ;D
