how to print Serial one time in loop
I am monitoring lamp condition which is on and off buy menually
i use this code for monitoring it work but it print continuous command i want to print it only one if lamp is ON or OFF
int i = 8;
int var;
pinMode(i,INPUT);
var = digitalRead(i);
if ( var == HIGH)
Serial.println("ON");
Serial.println("OFF");
please help me gys
You could use another variable say varPrev and compare var to it each time through loop(). If it changed, print; otherwise don’t. Each time through loop update varPrev with var.
Edit: Check the State Change Detection example.
A member already answered you questions but in case you want to try one that I used for the same purpose.
Here it is for you to try.
int i = 8;
int var;
byte toggle = 1 ;
pinMode(i, INPUT_PULLUP);
if (var == toggle ) {
return;
else if ( var == 1) {
Serial.println("ON" );
toggle = 1;
else if ( var == 0) {
toggle = 0;
thank you sooo much gys i actually got what i want .... :slight_smile: :slight_smile: :slight_smile:
