How to print special charactrers © ® ² "TM" in LCD display?
........Hola Arduino fans 8) For the following special characters, © - Copyright ® - Registered TM - Trade Mark ² - Square (Eg: X²) or power 2
what are the character codes? I have a HD44780U LCD Display with ROM Code: A00. For the above mentioned characters, there appears to be no code in the datasheet provided. But for ROM Code: A02, the codes are 169 for (c) & 174 for (R). But for others, there is no code. Any idea on how to make them appear on the display???
While I don't have an LCD display like yours, I believe it's the same principle for all kind of Arduino displays: you have to create those characters yourself with an array of bytes. Look the file "font.h" (I suppose) to see how each characters are defined. Include the font file in your reply here and I might help you make a character :)
I've never seen a datasheet with the codes expressed in decimal. I have no idea where to look on the Character Code chart to see if you are correct.
If you have a display that has actual IC chips on the back (instead of epoxy blobs) you can look at the part number on the controller chip. Mine is HD44780*A00. Assuming that your analysis of the Character Code chart is correct you would need one one with an HD44780A02* controller chip in order to get those characters. Good luck.
Don
Guys, its done…
#include  <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// ^2
byte newCharSquare[8] = {
  B01100,
  B10010,
  B00100,
  B01000,
  B11110,
  B00000,
  B00000,
  B00000
// (C)
byte newCharCopyright[8] = {
  B11111,
  B10001,
  B10101,
  B10111,
  B10101,
  B10001,
  B11111,
  B00000
// (R)
byte newCharRegistered[8] = {
  B11111,
  B10001,
  B10101,
  B10001,
  B10011,
  B10101,
  B11111,
  B00000
// TM
byte newCharTrademark[8] = {
  B01110,
  B00100,
  B00100,
  B00000,
  B01010,
  B10101,
  B10101,
  B00000
int i = 0;
  lcd.createChar(0, newCharSquare);
  lcd.createChar(1, newCharCopyright);
  lcd.createChar(2, newCharRegistered);
  lcd.createChar(3, newCharTrademark);
  lcd.begin(16, 2);
  for(int n = 0; n < 4; n++)
    lcd.setCursor(n,0);
    lcd.write(n);
Better give them meaningful names * newChar1 => newCharSquared * newChar2 => newCharCopyRight * newChar3 => newChar??? * newChar4 => newCharTRadeMark
easier to remember :)
robtillaart: Better give them meaningful names * newChar1 => newCharSquared * newChar2 => newCharCopyRight * newChar3 => newChar??? * newChar4 => newCharTRadeMark
thanks for the tip.... keeps us organized. I have modified the code accordingly.
