iviyan
August 1, 2023, 10:07am
1
I want to get the state of a pin and print it in the serial monitor but only when it has changed.
i tried doing it like this:
int valve = 4;
int savedState;
int valveState;
pinMode(valve, INPUT);
savedState = digitalRead(valve);
if (digitalRead(valve) != savedState) {
Serial.println(valveState);
it doesent work like I want it to though, it prints one state 100 times and it isnt even when the state has changed.
any help will be greatly appriciated!
PaulRB
August 1, 2023, 10:11am
2
Take a look at the "state change" sketch from the examples menu in the IDE.
Just a comment,
valveState isn’t being used in your code !
awneil
August 1, 2023, 10:55am
4
This will be fooled by switch bounce:
Try this:
valveState = digitalRead(valve);
if ( valveState != savedState) {
savedState = valveState;
It is now!
awneil
August 1, 2023, 10:57am
5
In the OP, It's being printed - but nothing ever updates it!
JCA34F
August 1, 2023, 11:02am
6
What is connected to pin 4?
Which pin is the valve connected to?
What changes the state of the valve pin?
iviyan
August 1, 2023, 3:33pm
9
currently im just connecting pin 4 to ground.
another variant that needs just a single line of code for printing info
#define dbgc(myFixedText, variableName) \
static long lastState; \
if ( lastState != variableName ){ \
Serial.print( F(#myFixedText " " #variableName" changed from ") ); \
Serial.print(lastState); \
Serial.print( F(" to ") ); \
Serial.println(variableName); \
lastState = variableName; \
int valve = 4;
int savedState;
int valveState;
dbgc("my fixed text",digitalRead(valve) );
best regards Stefan
iviyan:
if you have connected a typical mechanical button then this knowledge applies
dougp
August 2, 2023, 12:55am
12
So, a mechanical switch. Use INPUT_PULLUP on pinMode rather than just INPUT
Hello iviyan
Welcome to the worldbest Arduino forum ever.
Consider:
uint8_t valve = 4;
pinMode(valve, INPUT_PULLUP); // connected to GND
// memory to save old state
static uint8_t stateOld = HIGH;
// read current state
uint8_t stateNew = digitalRead(valve) ? LOW : HIGH;
// detect state changes
if (stateOld != stateNew)
// q&d debounce
delay (20);
// check current state changes
if (stateNew != digitalRead(valve) ? LOW : HIGH)
stateOld = stateNew;
Serial.print(F("valve ")), Serial.println(stateOld ? "becomes open" : "becomes closed");
You are seeing the switch bounce mechanically for about 2 ms.
What we do to fix it in software is wait until the pin reads the same for 2 ms or more (more especially for dirty switches) or just ignore the pin for a while and assume it is stable since it usually always will be if you wait long enough.
Making and improving your own debouncer is a bit of a rite. I check for stable state for ~3.5 ms before my button handler shows a stable state change.
You can get bounce-free sensing from light (often invisible near-IR) reflect or block or from magnetic sensor or magnetic switch, Hall types.
system
Closed
January 29, 2024, 5:28am
15
