I'm designing a controller for relay. I cannot use the PWM because the period is too small for relay application.
I want to use millis.. i have tried many times but failed..
can anyone help me please?
const int ledPin = 2; // the number of the LED pin // ledState used to set the LED
long current = 0; // will store last time LED was updated
long current2 = 0;
long period = 4000;
long offtime = 8000;
pinMode(ledPin, OUTPUT);
static unsigned long current = millis();
static unsigned long current2 = millis();
if(millis()-current > offtime)
digitalWrite(ledPin,HIGH);
current=millis();
if(millis()-current2 > period)
digitalWrite(ledPin,LOW);
current2=millis();
All your time variables should be unsigned longs.
Why are you declaring current and current2 again in loop() when they're declared already?
If you want the LED to alternate between on and off, you'll need a flag to keep track of it's state. Try this:
unsigned long current = 0; // will store last time LED was updated
unsigned long current2 = 0;
unsigned long period = 4000;
unsigned long offtime = 8000;
boolean flagLED =false; //LED off at start
current=millis() ;
void loop(){
if(millis()-current > offtime && flagLED ==false) {
current2=millis(); //set start of wait time for switch off
flagLED = true;
if(millis()-current2 > period && flagLED==true) {
current=millis(); //set start of wait time for switch on
flagLED==false;
Henry_Best:
or:
if (millis()-current < 8000UL ) digitalWrite(ledPin,HIGH);
else if (millis()-current < 12000UL) digitalWrite(ledPin,LOW);
else current = millis();
Henry_Best:
or:
Neat, except he wants the on time to be 4000 and the off time to be 8000. All he needs to do is to change the first line.
