How to program a Uno with another Uno (New to Arduino)
I fried one of my 16U2 on one of my Uno.
And now Im trying to learn how to program Uno using another Uno or Mega (I have both).
I have been looking around on the internet looking for solutions.
I found some one had similar problem before, here are some links that I use to try to solve the problem:
But after I try to do it myself I kept running into problems says
avrdude: stk500_getsync(): not in sync: resp=0x00
I saw something like I have to put a capacitor between reset and 5V.
I tried and it still gives me nothing.
Using above posts and now I am a bit confused. I do not know what I am doing or where I did wrong.
I followed every step and I still dont know how to do it.
I am completely lost.
To use USB interface of good arduino to download a program into another bootloaded Arduino:
Connect 5V to 5V, Gnd to Gnd, Tx to Tx, Rx to Rx.
On good arduino, connect Reset to Gnd.
Star the download - when IDE shows "compiled xxx of 32xxx bytes" press Reset on the 2nd arduino.
Have verbose outputs turned on under File:Preferences" can make it easier to get the reset timing correct.
CrossRoads:
So on the good arduino I just need to put a jump wire from Reset to Gnd? no capacitor needed?
I used these instructions without any problems.
...R
No capacitor needed. It will be the same as if you took the chip out of the board.
antonio6510:
Are you sure you have not simply scrambled it? Using the ISP (ICSP) header adjacent to "J2" and the 16U2, you may be able to re-flash it using the other UNO as ISP.
If it really is fried, then go get a proper USB to TTL adapter and use that instead of another UNO. You will still need the 0.1µF capacitor from DTR of the adapter to Reset.
Robin2:
...R
I tried this one too... But still didnt work....
CrossRoads:
Im still trying to figure out where i did wrong because Im still getting the error :
[/quote]
[/quote]
Yea.... unfortunately I tried to reset the 16U2 and didnt work out... found out I actually fried it
Could be the dead one is dragging down the lines. You could isolate it by removing RN4, which is the little 8-pin package next to the ICSP header; need to add a 1K resistor from the inside leg of the ON LED to +5 to show power is on. Or remove the 16U2 if you decide it really is bad (i.e. programming it doesn't work).
