Hello every one,,,
i am beginner in arduino programming.
I designed 3D CNC router machine .. using arduino uno, two stepper motor with it's shield and dc motor.
my power supply 12 v,,the size of the base of work 1m X 1m.
I want to learn write the program for the arduino to control the cnc,,because all the program i have ever
found in network did not work with the design that i made, also all the sources in google about cnc Gcode
programming, I did not found any source to learn arduino programming for cnc for beginners.
so from where i have to begin to learn step by step program for the cnc?
lighty
October 17, 2018, 8:48pm
2
Hey Safaa,
Cool that you're planning to build a CNC with Arduino.
This part of the forum is more for teachers and to share materials, so perhaps the Robotics thread would be better.
For 3D CNC's GitHub - gnea/grbl: An open source, embedded, high performance g-code-parser and CNC milling controller written in optimized C that will run on a straight Arduino is quite popular Usually people use a shield for the Arduino this will host the Stepper motor drivers and make the connections to the motors, endstops etc.
Here are some video's of people using Arduino to control a CNC
