How to program ATmega328P Microcontroller for 2 Axis Control
What I have is a dual axis control system that can be more accurate than NASA’s solar control. It will keep the dual axis platform aimed directly at the sun for maximum output of the solar cells. The control system can be as accurate as desired, and will even keep it out of the shade of adjacent platforms.
The earth is not round, it is slightly bulging at the equator; it is also tilted, and it wobbles somewhat. This is what causes the annual summer and winter solstices and equinoxes. Nothing ‘solar’ is exact, only close.
The control system can track the sun by time alone; but, if not exactly by time, then by sensor input. This will take into consideration the solstices and equinoxes year round.
The timing can be based on the longest day at the installed location worldwide. The altitude is controlled ‘UP’ in the a.m. and ‘DOWN’ in the p.m. hours. This is based on pre-and-post Solar Noon, not 12:00 o’clock noon, as the days are longer or shorter at varying locations. The following URL is for the Global Positioning System (GPS}. ESRL Global Monitoring Laboratory - Global Radiation and Aerosols It is ideal for determining the sunrise and sunset times, but, if the programming code could be embedded in the Microcontroller’s memory it would be much better. Even without that feature, GPS is still worthwhile for locating the systems anywhere on earth. It is not considered at this time to rotate the platform continuously, but, park it in the east at the very end of day.
I have a new code ready for posting, if you are ready to consider it. This code is based on melding two codes together, and removing the superfluous code. The code has a myriad of timed outputs, in lieu of just one. Any and all inputs as to the cause will be greatly appreciated. Thanks, and have a nice day.
Feel free to post your new code, but if you still haven't gone back and gotten the basic down then you'll just get told again to do so.
const int switchPin = 13;
unsigned long previousTime = 0;
int switchState = 0;
int prevSwitchState = 0;
int led = 2;
long interval = 110000;
unsigned long currentTime = millis();
unsigned long time;
  //start serial connection
  //configure pin 2 as an input and enable the internal pull-up resistor
  pinMode(2, INPUT_PULLUP);
  pinMode(13, OUTPUT);
  if (currentTime - previousTime > interval)
    previousTime = currentTime;
  digitalWrite(led, HIGH);
  led++;
  if (led == 12) {
  } // put your main code here, to run repeatedly
  if (switchState != prevSwitchState) {
    for (int x = 12; x < 13; x++) {
      digitalWrite(x, LOW);
    led = 12;
  prevSwitchState = switchState;
  Serial.print(0);
  time = millis();
  //prints time since program started
  //read the pushbutton value into a variable
  int sensorVal = digitalRead(2);
  //print out the value of the pushbutton
  Serial.println(sensorVal);
  //print out the value of the input sensor
  int digitalRead(A0);
  if (sensorVal == HIGH) {
    digitalWrite(13, LOW);
  }    else {
    digitalWrite(13, HIGH);
  if (sensorVal, A0 == HIGH) {
    digitalWrite(5, LOW);
  }     else {
  if (sensorVal, A1 == HIGH) {
    digitalWrite(6, HIGH);
    digitalWrite(6, LOW);
  if (sensorVal, A2 == HIGH) {
    digitalWrite(7, HIGH);
    digitalWrite(7, LOW);
  if (sensorVal, A3 == HIGH) {
    digitalWrite(8, HIGH);
    digitalWrite(8, LOW);
  if (sensorVal, A4 == HIGH) {
    digitalWrite(9, HIGH);
    digitalWrite(9, LOW);
    digitalWrite(10, HIGH);
    digitalWrite(10, LOW);
  } else
  if (currentTime - previousTime > interval) {
  led++; {
    if (led == 12) {
    led = 12;
// Interested only on duration of timed outputs, and if, GPS is doable.
First off, this is better than what you've posted previously. Still has plenty of issue but it is a step forward.
JackOWalden1Sr:
Which timed outputs? I can see that you're trying to read the inputs and turn the onboard LED on or off based on the input, but there is no timing method involved at all.
GPS is always doable but talking about that at the moment is definitely putting the cart before the horse.
The timed output dilemma is solved. My first thought was to use Pulse Width Modulation (PWM) to control the speed of the DC motors. Because the duration of the timing is so small, and the delay is so short, my second thought is that the PWM is more than adequate for timing; therefore, a fraction of a second out of 24 hours delay is tolerable.
JackOWalden1Sr:
Sure, but there is no timed outputs of any kind in the code that you've posted.
How about this code for motor control?
unsigned long previousTime = 9;
int switchState = 9;
int prevSwitchState = 1;
long interval = 0;
int pwm = 12; // assigns pin 12 to variable pwm
int pot = A0; // assigns analog input A0 to variable pot
int t1 = 0;   // declares variable t1
int t2 = 0;   // declares variable t2
void setup()  // setup loop
  pinMode(pwm, OUTPUT); // declares pin 12 as output
  pinMode(pot, INPUT);  // declares pin A0 as input
    unsigned long currentTime = millis()/1000;
  if(currentTime - previousTime > interval);
  t2= analogRead(pot); // reads the voltage at A0 and saves in t2
  t1= 1000-t2;         // subtracts t2 from 1000 ans saves the result in t1
  digitalWrite(pwm, HIGH); // sets pin 12 HIGH
  delayMicroseconds(t1);   // waits for t1 uS (high time)
  digitalWrite(pwm, LOW);  // sets pin 12 LOW
  delayMicroseconds(t2);   // waits for t2 uS (low time)
      digitalWrite(11, HIGH);
  delayMicroseconds(t2);   // waits for t2 uS (low time) // [3,5,6,9]
  if (digitalRead(A1) == LOW) // This indicates no light on sensor, and is on control.
    analogWrite(5, 30); // Ditto- on control.
  delay(225); // Indicates motor runs to bring back on control.
  if (digitalRead(A2) == LOW)
    delay(240);
  analogWrite(6, 30);
  delay(225);
  if (digitalRead(A3) == LOW) //This indicates on control.
    analogWrite(9, 15); // This indicates on control.
  delay(240);
  if (digitalRead(A4) == LOW) // This indicates on control.
    analogWrite(10, 15);
  delay(240);
You've obviously done away and done some researching, that's great. Having said that, there's a few things to get out of the way first:
Pin 12 doesn't support PWM, at least on the Uno.
Best bet to set your other outputs here too.
IF statements don't have semi-colons after them. You also need some brackets to make sure it is tested correctly- you want something like this:
  if((currentTime - previousTime) > interval);
IF statements also need braces.
The logic of the rest of your code doesn't make too much sense. You need to give us some more information on the motors that you are planning to use.
Thank you BJHenry,
The motors are of the type presented by: http://www.kinematicsmfg.com/
They are 24VDC bidirectional motors, driving gear boxes, with up to 156,000:1 gear box reduction ratios. The sizes range from LARGE to HUMONGOUS. The ATmega 328P Microcontroller will do a fine job controlling them.
All of the PMW circuits will be utilized, plus some others. Outputs 10 and 11 will be for West and Up directions, respectively. Circuits 3, 5, 6, and 9 are for North, East, South and West respectively. These will be active, only by the inputs of circuits A1, A2, A3, and A4. (The different numbers are because of the differing circuit characteristics), and can be further adjusted. This will drive the motors for less than one platform revolution per day. See the attachment for a representation. The outputs will encompass diodes to prevent voltage back-feed from the manual push-buttons. One additional circuit will park the motor in the east, at full speed, when day ends.One additional circuit will override the 'down' circuit to keep the unit in sunshine. The LEDS are for troubleshooting purposes.
Design1SensorsPage_1.pdf (196 KB)
Please tell me what is wrong with this code. It was cut and pasted from:
#include "CurieTimerOne.h"
  // Setup a PWM signal on pin 13, onboard LED, with a 25% duty cycle
  // of a 1 second period (1000000 usec), as follow (please note the
  // decimal point to indicate double):
  CurieTimerOne.pwmStart(13, 25.0, 1000000);
  // Or, use discrete number range, 0-1023, to define the duty period,
  // 255 is 24.9%, as follow:
  // CurieTimerOne.pwmStart(13, 255, 1000000);
  delay( 10000 );
JackOWalden1Sr:
https://www.arduino.cc/en/Tutorial/CurieTimer1PWM?action=sourceblock&num=1
(snip)
What makes you think there is something wrong with this code?
JackOWalden1Sr:
Thank you BJHenry,
Do the motors have built in drivers or are you going to use an external driver? Please post links to the datasheets of the drivers you're planning to use.
Thanks BJHenry,
Re: What makes you think there is something wrong with this code? It will not complie; gives this message- "Error compiling for board Arduino/Genuino" Error status 1.
Re: Do the motors have built in drivers or are you going to use an external driver? Please post links to the datasheets of the drivers you're planning to use. Ultimately, it will require multiple controls; my intent now is to get just one to market. The control is intended to control FETS (solid state relays) of the type located here:
https://www.arrow.com/en/manufacturers/adafruit-industries/diodes-transistors-and-thyristors/fet-transistors
One control, with 1 small FET per circuit, can act as a relay-control to energize many large contactors or, many controls with large FETS can give direct control to the motors. It seems to me that the 'control logic' would be the same for all.
Jack
JackOWalden1Sr:
Thanks BJHenry,
Have you installed the Arduino 101 core? It compiles fine for me when selecting the Arduino 101.
Do you refer to hardware, or software- everything '101' that I find refers to hardware?
JackOWalden1Sr:
The Arduino 101 is an arduino board. The example you linked is for the 101.
Will this do for me, what I want it to do? Please see the following:
https://www.cooking-hacks.com/projects/arduino-realtime-gps-gprs-vehicle-tracking#step4
It is a long code and produces Error Code, exit status 1 – stray ‘$’ in program. How to correct?
This, GPRS+GPS Quadband Module for Arduino, would be located on platform at the installation site.
Would anyone care to give me a price to debug my code?
The explanation details exactly what the code does- if you call it, it will send you an SMS with its GPS coordinates. Is that what you want it to do?
Yes, that will identify 'Time and Place' anywhere on Earth, and facilitate programming of the longest day, at that immediate location.
// Will this work?
float x;
  // Initialize serial communications
  Serial.begin (9600); // Initialiize serial communications.
  pinMode (8, INPUT); // Set the switch's pin to be an input.
  // read the switch
  int switchState = digitalRead(8);
  // read the sensor
  int sensorState = analogRead(A0);
  int pinMode = digitalRead(8);
  if (digitalRead(8) == HIGH) {
    analogWrite(3, 15);
    delay(240);
    int analogRead(A0);
    if (analogRead == HIGH) {
      digitalWrite(3, 15);
    }    else {
      digitalWrite(3, 240);
      int analogRead(A1);
        digitalWrite(5, 15);
      }    else {
        digitalWrite(5, 240);
        int analogRead(A2);
          digitalWrite(6, 15);
        }    else {
          digitalWrite(6, 240);
          int analogRead(A3);
            digitalWrite(9, 15);
          }    else {
            digitalWrite(9, 240);
            int analogRead(A4);
              digitalWrite(10, 15);
            }    else {
              digitalWrite(10, 240);
              int analogRead(A5);
                digitalWrite(11, 15);
              }    else {
                digitalWrite(11, 240);
