How to program matrix led (8x32) using Arduino Uno R3
Hi everybody!
I have just started to learn about Arduino. I have a Arduino Uno R3 and module matrix led (as attached image). I want to program displaying text, simple image… on module matrix led. Please showing me program. Does it has library of arduino for this.
Hope get your helps.
Best regard!
MatrixLed.pdf (662 KB)
So you bought a module that didn't come with example code? looks like you need to do some research with Google.
bin051:
Hi everybody!
Best regard!
It looks like the PDF file is a schematic of how you would hook up the panel and also additional circuitry you would need.
It looks very similar to circuit I saw for ShiftPWM library. That circuit chooses the column.
The 74HC595 are the shift registers.
And you can use 3 other pins to choose the row.
