How to program push button-LED+music
Hi, I am new to Arduino and I need some advice on what to get. I have a project in mind, I figure it's a great way to learn Arduino.
I am making a driod caller. I need the push button to activate the LED, after I let go, I want the LED to turn off and a pre-recorded R2D2 sound to activate. Each time I press the button and let go, a new sound activates. I would like to have 5-10 different sounds to happen. I need the board to be as small as possible. Questions:
  1. What board has this functionality? Would Adruino Mini work?
  2. Where would I start learning the code for this? Are there code "templates" I can work from?
Any other suggestions are great appreciated!
Thanks!
https://www.sparkfun.com/products/10653
thanks, but that ISD1932 board is too big. I need to to be around 1.5" x 3" or 4". Will the Adruino Mini work? Where could I find information on how to program this?
Thanks!
You can't use the arduino to store the music because it doesn't have enough ram. You have to use external chips or circuits.
